fuel plumbing question #714061
06/02/10 12:45 PM
06/02/10 12:45 PM
California
6superbee9 Offline OP
California
Hi guys,
I just swapped fuel lines and sending unit from 5/16 to 3/8. The pump is for the 5/16 set up but is only a year old. Do you think I'll have any drivability problems? I am not looking for high performacne just a driver. I do not want to get a new pump if i don't have to.
Thanks!
Re: fuel plumbing question [Re: 6superbee9] #714062
06/02/10 01:28 PM
06/02/10 01:28 PM
CHRGR69 Offline
CHRGR69  Offline
Hi guys,
Thanks!
Same question!
Grandma always said I had "hands of gold"!
Re: fuel plumbing question [Re: 6superbee9] #714063
06/02/10 03:51 PM
06/02/10 03:51 PM
A 5/16" pump w it's particular sized internal orifices will produce the same output no matter what size lines are used unless the input and output lines cannot handle what the pump is capable of drawing in and pushing out and a 5/16" pump is not going to restrict your stated useage. Short ans, you are good. I am assuming that your lines/sender needed replacing and you wanted 3/8" to handle the stroker that you are going to drop in sometime in the not too distant future EDIT if ever in doubt mount a psi gauge and if you have several psi AT THE CARB at the end of the strip (or street ) you have enough volume.
Re: fuel plumbing question [Re: RapidRobert] #714064
06/02/10 04:42 PM
06/02/10 04:42 PM
California
California
Thanks! Yes i did it to keep my options open
