Converter Slippage High "Powerglide" VIDEO ADDED #713916
06/02/10 01:34 AM
06/02/10 01:34 AM
Arizona
Chris'sBarracuda Offline OP
Arizona
Had the PIG out last Saturday Night @ the Quick 32 Arizonas Fastest Street Car Event @ Speedworld..
Anyway, finally got it down the track without an oil leak, trans leak, regulator going wild, or broken converter..
Ran the car all out @ 8:00 pm and the DA was about 3800'..
Went 9.15 @ 148.75 with a 1.30 60'
The high chip was set @ 7500 rpm. It was against it for 150'-200' says Billy D. EGT was 1270*
Shifted @ 6500.. Sounded like a 1 speed..Never heard it shift..
Next Run 9.08 @ 148.84 With 1.298 60'.. Same as first run.. Against the chip forever. EGT proves it.. went down to 1215*.. Shifted @ 6800.. Barely heard it change noise on gear change..
Another Run went 9.011 @ 148.94. 1.289 60'..
Didn't change anything.. Just the DA went down to 3000' by then.. The EGT was even lower 1170*
We also made a run on the T-Stop and went 10.82 @ 146 with a DA of 3800'... The EGT on that run was 1370*... So I know it wasn't against the chip..
I'm figuring the converter slippage @ 11.5%-12%
What I'm curious about is, can you tighten up a converters lock up and still have a high stall point? I would like it to stall @ 6200 in this air and still have 6%-7% slippage.. I think it is stalling @ 6700+ right now.
Chris..
Post deleted by Defbob [Re: Chris'sBarracuda] #713917
06/02/10 02:08 AM
06/02/10 02:08 AM
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713918
06/02/10 10:39 AM
06/02/10 10:39 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Sure they can... makes it more efficient
Re: Converter Slippage High "Powerglide" [Re: MR_P_BODY] #713919
06/02/10 10:45 AM
06/02/10 10:45 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I think you have heard me say this before. My 8" ATI stalls at 6200 and has 3% slip. Mine is WAY tight for all out runs but works perfect on the throttle stop. Keep after it you guys are chipping away it.
Re: Converter Slippage High "Powerglide" [Re: Al_Alguire] #713920
06/03/10 07:00 AM
06/03/10 07:00 AM
Arizona
Arizona
I have a fair video of one pass, but it is a new camera and I need to edit out some stuff. Not sure yet how to do it..
I'll post it if I can figure it out..
Where's Wild Bill when you need him..
Chris...
Re: Converter Slippage Powerglide #713921
06/03/10 09:27 AM
06/03/10 09:27 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
SOME USE JOHN DEERE HYDRAULIC FLUID
it tightens it up a few hundred
I've used hydraulic fluid for the same thing and it does work.
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713922
06/03/10 01:20 PM
06/03/10 01:20 PM
Jarrettsville, MD
cudaman1967 Offline
cudaman1967  Offline
Jarrettsville, MD
Chris,
Hydralic fluid will tighten convertor up about 200rpm. Easier than pulling trans out. If that makes it run faster you will then know the convertor is too loose. Data logging in best bet. If you do not have a full replay tach or a mega box than the fluid is your next easy change
Cudaman1967 1967 Barracuda Turbo Outlaw 8.50
Re: Converter Slippage High "Powerglide" [Re: cudaman1967] #713923
06/03/10 08:05 PM
06/03/10 08:05 PM
Arizona
Arizona
And here I thought Fred was pulling my leg. I've never heard of this before..
I may try this..
Chris..
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713924
06/04/10 12:11 AM
06/04/10 12:11 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
John Deere Hy-Gard...Been around and used in race trannies for years.
Re: Converter Slippage High "Powerglide" [Re: Al_Alguire] #713925
06/11/10 08:08 PM
06/11/10 08:08 PM
Arizona
Arizona
Finally got the video uploaded. Crew guys don't shoot good video..
http://www.youtube.com/watch?v=snkmp0AgFGU
Chris..
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713926
06/11/10 08:51 PM
06/11/10 08:51 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Chris...
Sorry, Must have missed this post yesterday somehow
Nice vid though
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713927
06/11/10 09:44 PM
06/11/10 09:44 PM
Great Lakes Region
abodiesonly1 Offline
Great Lakes Region
Nice Vid!
Definitely hearing it shift and didn't sound like it was on the chip at the other end.
What gear is in the glide?
Re: Converter Slippage High "Powerglide" [Re: Al_Alguire] #713928
06/11/10 10:10 PM
06/11/10 10:10 PM
Lehigh Acres, Florida
rickstershemi Offline
Yep same setup here only 6000 same percentage with the 8" ATI Treemaster....also tight off the stop
Hard to tell in the vid, but 11% could use improvement
Rickster
Re: Converter Slippage High "Powerglide" [Re: abodiesonly1] #713929
06/11/10 10:35 PM
06/11/10 10:35 PM
Arizona
Arizona
Nice Vid!
Glide has 1.76 ..
You can't hear a Crane ignition like you can an MSD, as Crane drops cylinders to control rpm.
Billy says he can definitely hear it in the car though.
That pass he shifted @ 7000, so you can hear it.
Wallace and other calculators show 11.7% to 11.8% slippage..
148.94 mph
7500 rpm
4.30 gear
102.25 circumference
The bars are too low and the car is porpoising..
I need to get the 60' down to 440Jims 1.22..
These are the first real runs off the stop, so were in learning mode here..
Chris..
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713930
06/11/10 10:47 PM
06/11/10 10:47 PM
Great Lakes Region
Great Lakes Region
Glide has 1.76 ..
148.94 mph
7500 rpm
4.30 gear
Chris..
Ok.....I missed what kind of ignition you had.
I was thinking I saw some tire unloading as I was trying to slow the vid down, but its a little grainy and dark for that. Theres def. some et in the 60' as its lifting and sitting right back down.
Looks great and once sorted is gonna be a runner!
Re: Converter Slippage High "Powerglide" [Re: abodiesonly1] #713931
06/11/10 10:58 PM
06/11/10 10:58 PM
Arizona
Arizona
As it looks now, it should be solidly in the 8's.
http://www.dragtimes.com/da-density-alti...rect+ET+and+MPH
Density Altitude: 3025 feet above sea level
1/4 mile ET: 9.011 seconds
1/4 mile trap speed: 148.94 MPH
Stock and Mildly Modified Naturally Aspirated Engines
8.684 @ 154.667 MPH
Extensively Modified Naturally Aspirated Engines
8.781 @ 152.943 MPH
Extensively Modified Supercharged and Turbocharged Engines
8.883 @ 151.077 MPH
The best part of all is that after the wreck and rebuild, Billy says it's like driving your couch on the top end.. So I guess we done good..
Chris..
Re: Converter Slippage High "Powerglide" [Re: Chris'sBarracuda] #713932
06/11/10 11:16 PM
06/11/10 11:16 PM
Great Lakes Region
Great Lakes Region
I was able to snag a decent pic from the vid!
Re: Converter Slippage High "Powerglide" [Re: abodiesonly1] #713933
06/11/10 11:23 PM
06/11/10 11:23 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I could here it shift...not alot of flash but more than you want i guess. Just glad you had a good outing, Chris.
Re: Converter Slippage High "Powerglide" [Re: B1Fish540] #713934
06/11/10 11:38 PM
06/11/10 11:38 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Just for info, here is a comparison of four different runs with two different converters and different rear gears. Stall speed is pretty much the same on all runs as was DA approximately, however coupling agressiveness is different, the more efficient convertor in this situation is the slower choice but has its advantages depending what you're wanting. Open attachment and view full screen.
Re: Converter Slippage High "Powerglide" [Re: 540dust] #713935
06/12/10 12:00 AM
06/12/10 12:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Hook up the tach wire in the delay box. Will show you exactly what RPM you are crossing at, or maybe you did that already. I fou nd it very useful when sorting my heap out.
Oh yeah...ATI......ATI.....ATI
BTW I agree that the most efficient convertor is not necessarily the fastest. My car is a full two tenths quicker with a horribly inneficcient converter that slips 21%. It puts a ton of heat in the trans but the car is clearly faster when it is in ther. In my case the 6200 stall is killing me, that is a good deal below torque peak for me.
