Had the PIG out last Saturday Night @ the Quick 32 Arizonas Fastest Street Car Event @ Speedworld..
Anyway, finally got it down the track without an oil leak, trans leak, regulator going wild, or broken converter..
Ran the car all out @ 8:00 pm and the DA was about 3800'..
Went 9.15 @ 148.75 with a 1.30 60'
The high chip was set @ 7500 rpm. It was against it for 150'-200' says Billy D. EGT was 1270*
Shifted @ 6500.. Sounded like a 1 speed..Never heard it shift..
Next Run 9.08 @ 148.84 With 1.298 60'.. Same as first run.. Against the chip forever. EGT proves it.. went down to 1215*.. Shifted @ 6800.. Barely heard it change noise on gear change..
Another Run went 9.011 @ 148.94. 1.289 60'..
Didn't change anything.. Just the DA went down to 3000' by then..
The EGT was even lower 1170*
We also made a run on the T-Stop and went 10.82 @ 146 with a DA of 3800'... The EGT on that run was 1370*... So I know it wasn't against the chip..
I'm figuring the converter slippage @ 11.5%-12%
What I'm curious about is, can you tighten up a converters lock up and still have a high stall point? I would like it to stall @ 6200 in this air and still have 6%-7% slippage.. I think it is stalling @ 6700+ right now.
Chris..
