Electrical Problems #713287
06/01/10 03:09 PM
06/01/10 03:09 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
I have a 65 Coronet 225. The first time I connected the battery this year, the fused wire between the starter relay and the bulkhead fuseblock burned. I replaced the starter relay and the wire-the same thing happened again. Could it be the solenoid on the starter? If not, what should I check? The battery is at full charge.
Thanks for the help.
Re: Electrical Problems [Re: vjb] #713288
06/01/10 03:14 PM
06/01/10 03:14 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
No
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: Electrical Problems [Re: HealthServices] #713289
06/01/10 03:16 PM
06/01/10 03:16 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
What might be the problem?
Re: Electrical Problems [Re: vjb] #713290
06/01/10 03:24 PM
06/01/10 03:24 PM
So Cal
So Cal
Give me a minute as I type slow. One possibility is you installed the battery backwards (sounds silly but people do it).
Another is the alternator.
Re: Electrical Problems [Re: HealthServices] #713291
06/01/10 03:26 PM
06/01/10 03:26 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Negative post to the starter?
Re: Electrical Problems [Re: vjb] #713292
06/01/10 03:34 PM
06/01/10 03:34 PM
So Cal
So Cal
NO . positive to the starter.
negative wire to the block
Re: Electrical Problems [Re: vjb] #713293
06/01/10 03:34 PM
06/01/10 03:34 PM
Andrewh Offline
Andrewh  Offline
you have a dead short somewhere or your fusible link is not rated for enough amps.
Start by pulling all the fuses, disconnect the large cable off the alt and insulat it so it doesn't touch anything.
Then put the fuses back one at a time till it pops again. see what circuit it is and figure out where your short is.
IF it still blows instantly, then unplug the headlight switch and horns.
Not sure what else always has power, but start looking at your wiring inside and the bulkhead connector for a short.
Might even bypass the amp meter just incase.
Re: Electrical Problems [Re: vjb] #713294
06/01/10 03:35 PM
06/01/10 03:35 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Sounds like a high amperage fault (short circuit) . . . . might want to check the ammeter connections - the one on the dash . . . could be they may have worked loose and are touching ground ???
As was mentioned before, possibly the alternator as well . . .
Just my
Mark
Re: Electrical Problems [Re: Andrewh] #713295
06/01/10 03:37 PM
06/01/10 03:37 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
Thanks alot for the advise.
I'm off to the garage-wish me luck.
I hate electrical.
Re: Electrical Problems [Re: HealthServices] #713296
06/01/10 03:41 PM
06/01/10 03:41 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
I feel like such an idiot!
Re: Electrical Problems [Re: vjb] #713297
06/01/10 03:45 PM
06/01/10 03:45 PM
So Cal
So Cal
Before you continue burning things up...
The positive (+) goes to the Starter
The negative (-) goes to the engine block.
Re: Electrical Problems [Re: vjb] #713298
06/01/10 03:46 PM
06/01/10 03:46 PM
So Cal
So Cal
It happens.
You are not the first
And you won't be the last
Re: Electrical Problems [Re: HealthServices] #713299
06/01/10 05:01 PM
06/01/10 05:01 PM
NW Indiana
deansrr Offline
deansrr  Offline
NW Indiana
well, aleast it was a simple fix!
1973 Road Runner 1974 Satellite (for sale) 1973 240z (wifes) 1993 Ramcharger (thanks Devil) 2002 Honda S2000
Re: Electrical Problems [Re: deansrr] #713300
06/01/10 09:01 PM
06/01/10 09:01 PM
Detroit, Mi
V
vjb Offline OP
vjb  Offline OP
V
Detroit, Mi
AND, it didn't cost too much (a few $$ and then my pride!)
