Page 1 of 4 1 2 3 4
New best ET and MPH today at <<<<the big L>>>>> #711950
05/30/10 11:18 PM
05/30/10 11:18 PM
S.E. Michigan
ZIPPY Offline OP
ZIPPY  Offline OP
S.E. Michigan
Still no 10s, but how about 11.02?
For now, it's close enough for me
It was a 45 minute drive in the GTX to Lapeer from my new place. I liked that alot compared to the 90 minute drive I used to have to Milan (which is now worse than before, at 110 minutes). I still don't have a trailer but decided no tire changing at the track....too hot out...so I just drove there easy on the QTPs and front runners I put on last night.
Ran from 11 to 2 o clock, got four runs in.
As far as conditions...Temp was 85 degrees, Mike said D/A was 2200 feet. Humidity was decent at 50%. Too hot for my blood, but other than that a great day to be out. If it wasn't for Mike's awning and SPF 60, I'd look like a cherry frosted donut though.
First run after a 4 year hiatus was supposed to be an easy check out pass, but once I got in the water box, I kinda said "screw it". Not knowing the lay of the land too well, though, I lifted after the et beams to learn the shutdown area a bit.
As it turned out I was racing a neighbor of mine who lives less than 1/2 mile away, in a 9 second camaro, although I wasn't sure who he was at the time. He redlighted.
I think it was his first pass of the day too....
r/t .842 (rusty)
60' 1.603 (decent, not where it needs to be, but...)
594ft 6.629
1/8ET 7.067
1/8MPH 98.36
1/4ET 11.02
1/4MPH 118.59 (result of lifting)
Cooled off for quite awhile and shot the breeze with the Moparts guys. Next run dropped tire pressure, and decided to run it out the back door...I knew the return roads, didn't like the 118mph and decided to fix that. Tire pressure, as it turns out, didn't make much difference but I wasn't super worried about it, and decided to just relax and drive the car for whatever it'd give me.
r/t .617
60' 1.654
594ft 6.701
1/8ET 7.159
1/8MPH 98.25
1/4ET 11.08
1/4MPH 4.02 (equipment error I guess)
I wasn't happy with that pass and was shaking my head at the end of it...I felt like I reacted to the last yellow worse than the first run, thought I missed my shift points a little, and so forth. On the return road I decided to hot lap it to see how the other lane felt...so 3 minutes later:
r/t .578 (finally, something...anything in the 5's)
60' 1.669 (meh...)
594ft 6.732
1/8ET 7.188
1/8MPH 98.61
1/4ET 11.103
1/4MPH 123.39 (That's more like it...Zippy likey )
Then it was time to eat lunch. Hot dogs all the way around...thanks again Mike for the use of your grill and everything...really appreciate that. Long cooldown, more bench racin' and kickin' back, and watching the sweat/salt stains grow on my T shirt.
After lunch Randy and I both wanted to go again, so we lined 'em up for the photo op which was fun.
Dropped the tire pressure again, but truthfully I didn't expect much of anything from that. I felt more comfortable in spite of being drenched with sweat...maybe the tiny bit of pressure from having a fellow Moparts member in the other lane helped a little bit? I got the same lane as the prior run.
r/t .510 ("I still got it!" It just took awhile to find it)
60' 1.637
594ft 6.713
1/8ET 7.17
1/8MPH 98.46
1/4ET 11.09
1/4MPH 123.15 (ZIPPY LIKEY)
I think this pass was best overall for the day although it wasn't the quickest. I reacted the way I wanted, hit my shift points the way I wanted...I drove it the best. Last night I changed the shift light from 6400 to 6200, thinking maybe I'd react to it slower, which turned out to be correct...so that little change helped me get the hang of it again sooner.
I'd probably lost a quart of perspiration by then, and had enough, so I quit while I was ahead. Watched/helped Randy change a carburetor and make a solo pass, loaded tools/safety stuff/etc back into the GTX and drove it back home.
I'm really pleased I finally got the car out again, and don't have a problem with 11.0 at 123 under those conditions....especially driven to the track, and driven back home afterward.
Like always, there's more in it!
Good times ahead for sure
Thanks for reading...
Rich H.
Esse Quam Videri
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711951
05/30/10 11:38 PM
05/30/10 11:38 PM
San Diego CA
65 Hemi Offline
65 Hemi  Offline
San Diego CA
Nice! Sounds like you had fun. What's the combo(engine,gear, converter, and weight)?
Doug
MOPAR or NO CAR!!!
1965 Dodge Coronet soon a 6.1 Hemi with a Magnson blower 810 hp on pump gas
1964 Dodge Polara 582" Indy alum Block 426-1RA heads,
1933 Plymouth PE all Steel, LT1 4L60E
1959 Plymouth Savoy 33,000 mile survivor
Old cars are never done. They are ongoing projects!
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711952
05/30/10 11:38 PM
05/30/10 11:38 PM
MR_P_BODY Offline
MR_P_BODY  Offline
was a good time today... hot... yes but at
least the wind was blowing some..... oh... congrats on
your new best
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711953
05/30/10 11:43 PM
05/30/10 11:43 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Good going and that 10 is there..............
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: Thumperdart] #711954
05/30/10 11:45 PM
05/30/10 11:45 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Your really zippin!!That 10 sec pass will occur this year
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Post deleted by Defbob [Re: hemi-itis] #711955
05/30/10 11:49 PM
05/30/10 11:49 PM
Re: New best ET and MPH today at <<<<the big L>>>>> #711956
05/31/10 12:54 AM
05/31/10 12:54 AM
Chesterfield Twp. Mi.
John Burdine Offline
congrats Zippy, got yourself a 10 second car for sure.
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711957
05/31/10 01:07 AM
05/31/10 01:07 AM
Bloomingdale , OH
super451b Offline
super451b  Offline
Bloomingdale , OH
Sounds like you had a good day ! Congrats on the new best! You should be solidly in the 10's when you get some good air and probably before that if you can get it to hook.
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: super451b] #711958
05/31/10 01:09 AM
05/31/10 01:09 AM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
WIZE
In Car:
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711959
05/31/10 06:22 AM
05/31/10 06:22 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It got up to about 90* with a DA of 3300' humidity
stayed at 50% most of the day
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: MR_P_BODY] #711960
05/31/10 06:46 AM
05/31/10 06:46 AM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Good to see your back out and had a successful day at the track,,10's for sure
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: dartman366] #711961
05/31/10 06:54 AM
05/31/10 06:54 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
Sounds like 10's the next time out!
Plynouth VIP '67 TT IC EFI
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: jyrki] #711962
05/31/10 07:01 AM
05/31/10 07:01 AM
ohio
all spooled up Offline
ohio
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: all spooled up] #711963
05/31/10 09:36 AM
05/31/10 09:36 AM
Clinton Twp... north of Deetro...
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Rich..I'm glad your X ran so well! I was happy with my 11.20's and 30's,also! Especially under those weather conditions! With the xtra torque of the dominator,I need some new slicks out back!!! IT WAS FUN!!
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: Labratt] #711964
05/31/10 10:08 AM
05/31/10 10:08 AM
Ortonville, MI
RoadRnnr69 Offline
Keyster
RoadRnnr69  Offline
Keyster
Ortonville, MI
That is great Zippy!!!
It will hit 10's for sure!!!
So will you Randy with that Dominator!!!
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: RoadRnnr69] #711965
05/31/10 11:03 AM
05/31/10 11:03 AM
Labratt Offline
Good Ol Randy B!
Labratt  Offline
Good Ol Randy B!
Keith...you might be right! I won't find out until I get some new "skins"! Mine are pretty much gone!!! Must be those "John Force burnouts" Raffy just LOVES those!
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711966
05/31/10 11:16 AM
05/31/10 11:16 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello Zippy,
You are doing what I want to some day accomplish. My drive is only 30 minutes but it's cool to roll off the freeway and onto the track laying down some fun times. I'm looking for 10's also. Hey you need to update your signature!
Damon
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: Labratt] #711967
05/31/10 11:19 AM
05/31/10 11:19 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Side track............. I found out why the AC didnt
want to play(well almost found out... still testing)
but its either the start/run capacitor or the compressor
decided to take a DUMP... of course on the hottest day
Ok.... back to the normal biz
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: MR_P_BODY] #711968
05/31/10 11:56 AM
05/31/10 11:56 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Now THAT's what I'm talking about! 45 min of drive time, 11.0's @ 123 and drove it back home!
SWEEEET!!!
What's the combo, Zippy??
Re: New best ET and MPH today at <<<<the big L>>>>> [Re: ZIPPY] #711969
05/31/10 11:57 AM
05/31/10 11:57 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Congrats on your new best!
Driving to the track ready to race and then a new best, it doesn't get much better than that.
Your 10 second pass is coming very soon!
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Page 1 of 4 1 2 3 4
