Re: What am I doing wrong? caliper hose still leaking
[Re: wh23g3g]
#711512
05/30/10 05:13 PM
05/30/10 05:13 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
You do know you need a washer on each side of the fitting, right?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: wh23g3g]
#711513
05/30/10 05:14 PM
05/30/10 05:14 PM
RapidRobert
You need the MP washers (4 total) that have the circular rings like a tree trunk and check that they are thick enough to be higher than the recess in the calipers and check for no burrs/debris on the contact surfaces on the hose fitting nor the caliper recess and that the washers slightly nestle into the matching circular grooves on the hose fitting.
[Re: wh23g3g]
#711522
06/02/10 10:17 AM
06/02/10 10:17 AM
Posts: 199 douglasville,ga
ramrod
douglasville,ga
Try this: Use the original Chrysler washers, but before you install them heat them up red hot with a propane torch and then immediately drop them in cold water. Copper work hardens easily and this will soften them up a bit.
"That Plymouth had a Hemi with a Torqueflite."
-Driver
[Re: ramrod]
#711523
06/02/10 01:26 PM
06/02/10 01:26 PM
Posts: 2,034 NW Indiana
deansrr
NW Indiana
try swaping bolt with other side and see if it leaks, then try swaping washers, hose ect, till you see which part is causing the leak, narrow it down to find the problem. good luck
1973 Road Runner
1974 Satellite (for sale)
1973 240z (wifes)
1993 Ramcharger (thanks Devil)
2002 Honda S2000
[Re: wh23g3g]
#711525
06/03/10 10:36 PM
06/03/10 10:36 PM
deansrr
NW Indiana
flat sided to hose, are you sure you have the right size gaskets?
1973 Road Runner
1973 240z (wifes)
2002 Honda S2000
