NEED HELP ( WIRING) #711469
05/30/10 01:12 PM
05/30/10 01:12 PM
nebraska
69coronet440 Offline OP
nebraska
I have a 69 coronet r/t. I have a problem with the pass. brake light and turn signal. If I have the lights on I have tail lights left and right. When I hit the brake or use the turn signal the pass. side doesn't work? I can't seem to figure it out I need some advice. THANKS!
Re: NEED HELP ( WIRING) [Re: 69coronet440] #711470
05/30/10 01:16 PM
05/30/10 01:16 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Try grounding the light housing... most times there are probems with the lights, it's ground problems.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: NEED HELP ( WIRING) [Re: 69coronet440] #711471
05/30/10 01:48 PM
05/30/10 01:48 PM
the pass brake light and TS light is the same large filament in the bulb (small filament is the tail light). You're saying the pass taillight works but the pass ts/brake light does not? (1) Check the bulb which I'm sure you have done. (2) have someone hit the brake & see if the round nub contact at the base of the bulb (the one for the large filament) is getting fire (3) as said see if the socket is grounded (a jumper wire w alligator clips on each end to connect the metal socket to a KNOWN GOOD ground will ans that Q. Go Big Red.
