tti header guestion #710845
05/29/10 03:22 PM
05/29/10 03:22 PM
ny
DoctorD Offline OP
DoctorD  Offline OP
ny
Does the drag link connect under the headers or thru; old headers was thru on drivers side but new tti looks like it will be under. forgot to say 72 duster
Re: tti header guestion [Re: DoctorD] #710846
05/29/10 06:24 PM
05/29/10 06:24 PM
Maryland
dduster73 Offline
dduster73  Offline
Maryland
On my 440/4 speed 73 Duster it goes underneath the 1 3/4 TTI headers. Not clear on your engine.Check the TTI website. Dave
Re: tti header guestion [Re: DoctorD] #710847
05/30/10 12:45 AM
05/30/10 12:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I am guessing that you are running a small block?
The TTI headers fit above the steering linkage in all apps from 67-76. It may be helpful to remove the drag link during the header install anyways, just for added room.
Re: tti header guestion [Re: Kern Dog] #710848
05/31/10 05:36 PM
05/31/10 05:36 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
You have to remove the drag link to get the passengers side header in. And yes all the tubes run above the steering linkage. I had to push my engine back 1/4" to get good steering linkage clearance.
