my axles move in and out 1/4" What now?
#710464
05/29/10 10:22 AM
05/29/10 10:22 AM
Posts: 801 central CT
cudazappa
central CT
OK, just started working on my Challenger for the long weekend.
I started by inspecting the rear wheels because I thought that the rear oil seals had gone bad. I had gear oil coming out the brakes at the car's first autocross.
Rear end is an 8.75 with 741 with 3.23 SG. I changed out the 741 with 3.23 open.
My method was pulling the axles, R&R'ing the pumpkin, and reinstalling the axles. I had no problems until I brought the car out to the AutoX.
So today, I looked at everything and the axles wiggle 1/4" in and out of the housing. I took out the passenger side axle to inspect it, and nothing looks out of place, but obviously, something has moved. The adjuster cannot take out the slack.
Right now I'm postulating that the press fit on the bearings and backup collar wasn't enough for the autox and they've slid down. I could press them down again (I have the press and could do that) but I don't know how far, etc... Also, this problem may (will, probably) return, so it'd be nice to kick it in the butt now.
So the question is, what now do I do? Bring the axles to a shop? Bring the whole car? I'm in a quandry, and I'm pretty lost.
1971 Challenger
Re: my axles move in and out 1/4" What now?
[Re: cudazappa]
#710465
05/29/10 10:25 AM
05/29/10 10:25 AM
Posts: 2,826 NY usa
540challenger
NY usa
Did you check to see if the thrust spacer was inside the new center section you installed on some carriers the roll pin breaks and the spacer falls out and you might not catch it. unless you look
[Re: 540challenger]
#710466
05/29/10 10:50 AM
05/29/10 10:50 AM
cudazappa
central CT
Do you have a picture of this?
The axles go in to where they should be, but they come out 1/4". They don't go into the drum any extra then they did before...
1971 Challenger
[Re: cudazappa]
#710467
05/29/10 11:07 AM
05/29/10 11:07 AM
Posts: 8,016 Polson, MT
DoctorDiff
Polson, MT
I agree. Sounds like you are missing the thust buttons in the differential. Without the buttons, the axles fall into the housing, and you cannot adjust wheel bearing lash. The thust button is illustrated in the center and toward the bottom of the page in this link: http://www.moparts.org/Tech/Archive/axle/13.html
[Re: cudazappa]
#710470
05/29/10 02:02 PM
05/29/10 02:02 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
If you have a small hole you can see light thru the block is most likely missing.
If the Third member was out you could push and pull on the pin with a magnet on a stick and it would move back and forth about a 1/4 to 1/8 (?) of a inch.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: DoctorDiff]
#710471
05/29/10 03:24 PM
05/29/10 03:24 PM
cudazappa
central CT
I am DEFINITELY missing the thrust buttons...
Also discovered I have a clutch type SG.
Where can I get these?
thanks for all the help so far!
1971 Challenger
[Re: cudazappa]
#710472
05/29/10 04:24 PM
05/29/10 04:24 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I'd send you mine but mine went ... I'm sure Doctordiff could sell you one if he has any. Email him if he does not respond. He is a busy man.
Allen
[Re: ProStDodge]
#710480
05/30/10 09:19 AM
05/30/10 09:19 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Or you could install a new set of "green" axle bearings and no longer need the thrust block and no longer need to adjust the bearings.
Yep you could do that but you would be getting a lesser quality bearing (yes greens are fine but not as good as the tapered) and added expense of the bearing and the pressing on and off. Plus it isn't as if adjusting the endplay was a process that was constantly repeated. but once done it is done. And takes all of about 5 extra minutes.
[Re: ProStDodge]
#710482
05/30/10 10:17 AM
05/30/10 10:17 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
I wouldn't put greens in a car I planned to AUTOCROSS
