What rockers to use on INDY 440-EZ 295 #710405
05/29/10 06:14 AM
05/29/10 06:14 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Well we bust a rocker arm on my buddy's motor this weekend they're the nasty INDY black ones. Think its time to upgrade to something better just wondered what people used and whats recommended?
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710406
05/29/10 06:58 AM
05/29/10 06:58 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
If budget is not a problem then Jesel or T&D would be my choice
I have heard good reports on the Aussie ones, name escapes me.. Yella terra ?
What ratio are you after 1.5 or 1.6 as this may limit your choice
What was the reason for breakage, metal fatigue ?
what spring pressures you running
Hows your Cuda ?
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710407
05/29/10 07:14 AM
05/29/10 07:14 AM
NC
440Jim Offline
440Jim  Offline
NC
What valve spring pressures are they running? seat and open
Re: What rockers to use on INDY 440-EZ 295 [Re: mopar_mark] #710408
05/29/10 07:20 AM
05/29/10 07:20 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Hello mate hows things? My Cudas still a big pile of bits slowly coming together. Johns Cudas dead and not going anywhere by the looks of it grrrrr. Suspect possible over rev or may just be simply because these INDY rockers are cheese! Apparently they're known for breaking! Not sure on spring pressures etc as the motors pete wisemans old one from the dart and we havent many specs on it. Hauser built it but doesnt know all the details. Hows the Cuda going? Fancy lending us your motor for the weekend?
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710409
05/29/10 07:56 AM
05/29/10 07:56 AM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
All being well, will be at the track tomorrow (Avon Park), just waiting for the rain to stop, so I can switch over the slicks & start loading up on the trailer, maybe see you there
Re: What rockers to use on INDY 440-EZ 295 [Re: mopar_mark] #710410
05/29/10 08:04 AM
05/29/10 08:04 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Thats a bummer mate were at the pod! Absolutely hammering down here its been rainig solid since about 9AM. Good luck tomorrow mate go get that 8! Keep me posted on here if you can and let me know how you get on!
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710411
05/29/10 08:07 AM
05/29/10 08:07 AM
NC
440Jim Offline
440Jim  Offline
NC
With a good roller cam spring pressures, the Indy rockers are known for breaking after time. The more pressure, the shorter the time. They seem to hold up just fine with solid lifter (flat tappet) cam, valve spring pressures (135# seat, 370# open).
Re: What rockers to use on INDY 440-EZ 295 [Re: 440Jim] #710412
05/29/10 08:13 AM
05/29/10 08:13 AM
united kingdom
blown360 Offline OP
blown360  Offline OP
united kingdom
Running a roller not entirely sure on lift havent checked it yet and dont have the cam card either. My buddy just bought the motor and we bolted it in!
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710413
05/29/10 11:00 AM
05/29/10 11:00 AM
Chattanooga,Tn
Mopar Racer Offline
Mopar Racer  Offline
Chattanooga,Tn
I am running the Indy EZ 295 CNC heads on my 512 low deck engine.I have the old Comp 650 solid cam with 150 to 160 closed seat pressure and around 370 open.I have a set of the Hughes Engines 1.5 rockers with their banana grooved shafts and their hold down kit.Everything assembled nicley and has not given me any trouble at all.I started running the car back in February and as of now I have close to 100 passes on the engine.
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710414
05/29/10 11:41 AM
05/29/10 11:41 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Indy heads + standard offset rockers + roller cam = Harland Sharp... at least IMO.
Re: What rockers to use on INDY 440-EZ 295 [Re: BradH] #710415
05/29/10 11:45 AM
05/29/10 11:45 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
yes
Re: What rockers to use on INDY 440-EZ 295 [Re: blown360] #710416
05/29/10 02:09 PM
05/29/10 02:09 PM
AndyF Offline
AndyF  Offline
I use the RAS rocker arms on my stuff. They can be hard to find though as they only produce a small number of them each year.
Re: What rockers to use on INDY 440-EZ 295 [Re: jamesc] #710417
05/29/10 05:15 PM
05/29/10 05:15 PM
yes
that makes 3 of us. no doubt that's what i'd put on them. buy a good set of rockers now and you'll never worry about them again.
Re: What rockers to use on INDY 440-EZ 295 [Re: mopar_mark] #710418
05/29/10 06:44 PM
05/29/10 06:44 PM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
Hows your Cuda ?
I didnt know yella terra were making rockers for indy heads?? if they are they will be quality peices.
Re: What rockers to use on INDY 440-EZ 295 [Re: SG duster] #710419
05/29/10 10:20 PM
05/29/10 10:20 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I ran harlands on my old set
Mopar Performance
