Z-Bar Bracket #710277
05/28/10 11:06 PM
05/28/10 11:06 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
Converting a 66' Slant 6 Belvedere Convertible from auto to a 383 4 speed. Bought the bracket for the Z-Bar but where do I weld it? I thought there would be a slot in the frame to position it. Do I have to mock up the tranny & bell housing? Mark
Re: Z-Bar Bracket [Re: m300b] #710278
05/29/10 03:31 AM
05/29/10 03:31 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Here's one on an A-body looking into the wheel arch.
Re: Z-Bar Bracket [Re: m300b] #710279
05/29/10 07:52 PM
05/29/10 07:52 PM
Jacksonville Florida
elitecustombody Offline
there should be a plug that will have to come out,once you locate that hole,it's piece of cake
Re: Z-Bar Bracket [Re: nz383man] #710280
05/29/10 07:53 PM
05/29/10 07:53 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
The B& E body have a bracket that welds to the inside. I just don't know exactly where it goes.
Re: Z-Bar Bracket [Re: elitecustombody] #710281
05/30/10 12:04 AM
05/30/10 12:04 AM
ohio
m300b Offline OP
m300b  Offline OP
ohio
No Plug, no slot.
Re: Z-Bar Bracket [Re: m300b] #710282
05/30/10 07:33 AM
05/30/10 07:33 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Here ya go....
web page
Re: Z-Bar Bracket [Re: Commando1] #710283
05/30/10 01:47 PM
05/30/10 01:47 PM
ohio
m300b Offline OP
m300b  Offline OP
ohio
Thanks for your help, I will mock up the block and belhousing and go from there.
Re: Z-Bar Bracket [Re: m300b] #710284
05/30/10 03:04 PM
05/30/10 03:04 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
Make sure you get the Z bar straight and level, with a Lakewood can you may have to shorten it (the Z bar) a half inch os so, And don't forget to make some sort of a torque strap for your motor or you will have shifting issues. Otherwise it's a piece of cake.
