Re: What rockers are you using with sb eddy heads ?
[Re: Challenger 1]
#708800
05/27/10 12:04 PM
05/27/10 12:04 PM
Posts: 84 NC
Badfish67
NC
Call up Harland Sharp and speak to Randy Jr. or Mike on the tech side have them to set you up with their roller rockers that are made special for the small block Eddy heads. They will fit right on with no grinding or shimming.
1967 Barracuda
360ci/727
9.723ET @139.44mph
[Re: Alikazam]
#708803
05/27/10 10:03 PM
05/27/10 10:03 PM
Posts: 3,024 NY
B1duster
NY
[Re: AndyF]
#708805
05/28/10 12:32 AM
05/28/10 12:32 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
On 73 Duster with eddy heads, have ran stock non adjustable rockers and crane ductile iron..the ductile iron rockers are about 25 yrs old..still using springs between rockers on shaft.
on 71 Dart with 360 and eddy heads using crane gold 1.6 rockers..
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: AndyF]
#708806
05/28/10 07:08 PM
05/28/10 07:08 PM
Posts: 3,024 NY
B1duster
NY
I have a set of comps I bought at a swapmeet. Wanted to use them but after marking the valve tip blue and turning the motor by hand, the mark was about 2/3 of the way across the valve tip. Shimming up was worse. Is it possible the stands need to be milled down ??? Can I run it that way on the street or will it kill the guides ??? Plan to try again with a new set of crane golds.
[Re: AndyF]
#708808
05/28/10 07:37 PM
05/28/10 07:37 PM
Posts: 571 Beaverton, OR, USA
Alikazam
super gas
super gas
Beaverton, OR, USA
The Comps work fine on my 427 inch SB.
Andy, are those Eddy's ported? Did you do it yourself? Just thinking about this for the next "go around" on my 360... Beehive springs? Sorry to side track! ![](/ubbthreads/images/graemlins/smile.gif)
