2002 Dakota ac drain tube location?? #708488
05/26/10 04:48 PM
05/26/10 04:48 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I can't find the ac drain tube on my v8 truck... It's getting the floormats wet, can I not just drill a hole in the ac evap box and put in my own tube through the firewall? This seems to be a huge problem on Dakotas..
Re: 2002 Dakota ac drain tube location?? [Re: da50r] #708489
05/27/10 12:17 AM
05/27/10 12:17 AM
Columbus Ga
reflections7 Offline
Columbus Ga
There is a teardrop look to the vent/heater box under the pass carpet . you can pull it back and see it from the top. drill a small hole in the very center of the teardrop area and stick a coathanger thru and it will unclog the drain that goes into the frame rail then just a piece of tape over the plastic you drilled the hole in. At least thats how I remember it. I believe there was a T.S.B. on it.
Re: 2002 Dakota ac drain tube location?? [Re: reflections7] #708490
05/27/10 11:16 AM
05/27/10 11:16 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
How big is this teardropped thing I'm supposed to unclog.?? So the ac drip tube is not on the firewall on this truck? I can't see it if there is! Thanks!!!
Re: 2002 Dakota ac drain tube location?? [Re: da50r] #708491
05/27/10 11:41 AM
05/27/10 11:41 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
IIRC the deletion of the tube was the beancounters way of saving a nickel on every truck out the door. You will need what is known as a "donkey d*ck" and I **believe** the p/N is 5264688 Tube. It has been awhile so please forgive me if there is an error.
Common sense is a flower that does not grow in everybody's garden
Re: 2002 Dakota ac drain tube location?? [Re: Ron_M] #708492
05/27/10 12:01 PM
05/27/10 12:01 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Don't drill that hole. Put the donkey thing on. Water runs back along the outside of the drain tube and into the passenger compartment. Thats the reason for the extension.
Re: 2002 Dakota ac drain tube location?? [Re: Todd] #708493
05/27/10 02:08 PM
05/27/10 02:08 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
I took mine in to the dealer and they fixed it for free. Very common issue on those I guess.
Re: 2002 Dakota ac drain tube location?? [Re: bobby66] #708494
05/27/10 08:47 PM
05/27/10 08:47 PM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
I could not even come close to finding that tube.... I'll take it to the dealer... thanks guys.... I hate taking things to the stealership, but.... I don;t have time to mess with my daily drivers any more!!
Re: 2002 Dakota ac drain tube location?? [Re: da50r] #708495
05/28/10 10:19 AM
05/28/10 10:19 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
