4-speed i-d ? #708321
05/26/10 12:46 PM
05/26/10 12:46 PM
ar
bobs68 Offline OP
bobs68  Offline OP
ar
Took a four speed out of the roadrunner. What #'s tell me what it is and where are they located. Thanks
Re: 4-speed i-d ? [Re: bobs68] #708322
05/26/10 04:13 PM
05/26/10 04:13 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
my chrystal ball says its a 833 trans, now you need to determine if is a 18 or 23 spline unit..... Im betting a 23 spline..
I am truckless..
Re: 4-speed i-d ? [Re: 340SHORTY] #708323
05/26/10 04:22 PM
05/26/10 04:22 PM
ar
bobs68 Offline OP
bobs68  Offline OP
ar
It's 23
Re: 4-speed i-d ? [Re: bobs68] #708324
05/26/10 08:36 PM
05/26/10 08:36 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
If it has a VIN pad on the passenger side, what are all the numbers on it?
Re: 4-speed i-d ? [Re: Alaskan_TA] #708325
05/26/10 09:52 PM
05/26/10 09:52 PM
ar
bobs68 Offline OP
bobs68  Offline OP
ar
on the passanger side- Don't see a vin pad but there are some #'s c96561h on the main body and on the tail shaft #'s c-96707j
Re: 4-speed i-d ? [Re: bobs68] #708326
05/26/10 11:13 PM
05/26/10 11:13 PM
Milwaukee, WI
In_The_Pink Offline
In_The_Pink  Offline
Milwaukee, WI
Look for this raised pad on the pass. side of the main case, then report back with the numbers and letters.
Re: 4-speed i-d ? [Re: In_The_Pink] #708327
05/26/10 11:29 PM
05/26/10 11:29 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
With no VIN pad it may be 1967 - 1968 model year or earlier.
Re: 4-speed i-d ? [Re: Alaskan_TA] #708328
05/27/10 12:02 AM
05/27/10 12:02 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
I'll guess its a 68
(his user name is bobs68 )
