Gains from intake swap? #707599
05/25/10 06:41 PM
05/25/10 06:41 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
Here's my combo:
440 .055 over, 4.25 crank
Procomp CNC heads
Comp XR292 hyd. Roller, .585/.580 w/ 1.6 Hughes Rockers
Proform 950 Race Series carb
Edelbrock RPM intake
Motor made 572HP @5700 and 620 ft-lbs @3600
I chose the RPM intake with hood clearance in mind, but I had to order a six-pak hood anyway b/c of the ProComps.
My question is, will it be worthwhile to swap to a Victor or Indy intake? How much HP do you guys think I will pickup with an intake swap?
Re: Gains from intake swap? [Re: kzinge1] #707600
05/25/10 07:39 PM
05/25/10 07:39 PM
fullmetaljacket Offline
The Victor really awakes in the mid range and up.
Though it is responsive even in the low end on a middle weight car.
Depending on your duration, Head work, gearing etc the Vic may pick you up a little or better.
I would await for some intake gurus on this board that will set you in the right direction.
My Vic works swell with my stage 2 ported heads and stock port windows.
Re: Gains from intake swap? [Re: fullmetaljacket] #707601
05/25/10 08:33 PM
05/25/10 08:33 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
The heads are fully ported and the duration on my cam is about 250* @.050. Car is a 69 RR w/ 3.55 gears. I can afford to lose a little down low if the HP gains are there.
Re: Gains from intake swap? [Re: kzinge1] #707602
05/25/10 08:43 PM
05/25/10 08:43 PM
Modesto, CA
Chris_Holton Offline
Modesto, CA
I just ported a big block chevy manifold (R&R) on the dyno, It gained 28 H.P. from out of the box form, so yes, the Intake can make a large difference if your going from a fair to a good manifold....
Re: Gains from intake swap? [Re: kzinge1] #707603
05/25/10 09:19 PM
05/25/10 09:19 PM
Alberta, Can
JUST_N_TIME Offline
JUST_N_TIME  Offline
Alberta, Can
If the RPM intake is port matched to the heads I doubt you will gain anything in the rpm ranges you have indicated - and you will loose tq in the 2-4k range
Re: Gains from intake swap? [Re: JUST_N_TIME] #707604
05/25/10 09:36 PM
05/25/10 09:36 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
700ho easy with a Victor Intake and a real cam. Put a cam in it that will let the engine RPM, and take advantage of some of that good flow rate...
Re: Gains from intake swap? [Re: Bob_Coomer] #707605
05/25/10 09:42 PM
05/25/10 09:42 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
M1 two inch spacer
or victor 440
1.39 9.85 - 137 mph
Re: Gains from intake swap? [Re: Bob_Coomer] #707606
05/25/10 09:42 PM
05/25/10 09:42 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
The RPM is port matched to the heads. And I will eventually go to a big solid roller. At that time I will definitely swap intakes, but I was thinking if I could make some decent gains I would go ahead and swap now. How much HP does the Indy dual plane support?
Re: Gains from intake swap? [Re: Ari440] #707607
05/25/10 10:55 PM
05/25/10 10:55 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
M1 two inch spacer
or victor 440
And experiment with spacers on the Victor too, if you go that way.
Rich H.
Esse Quam Videri
Re: Gains from intake swap? [Re: ZIPPY] #707608
05/25/10 11:05 PM
05/25/10 11:05 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
I do have a 1" 4-hole tapered spacer on the RPM now, I will try it if I go with the Victor. Hood clearance might be an issue with the spacer, though. Even with the six pak.
Re: Gains from intake swap? [Re: kzinge1] #707609
05/26/10 03:07 PM
05/26/10 03:07 PM
Louisiana
K
kzinge1 Offline OP
kzinge1  Offline OP
K
Louisiana
Bump
