need help with T&D rockers #707317
05/25/10 02:14 PM
05/25/10 02:14 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
I had my indy 360-1 heads fully cleaned up with a full port job, milled and new springs installed at 2.00" install height. My problem now is the underside of the rockers are hitting the valve retainers and T&D tells me i'm stuck, no way to correct this unless i buy different set of their rockers.
Re: need help with T&D rockers [Re: mopar dave] #707318
05/25/10 02:29 PM
05/25/10 02:29 PM
412 SB Duster Offline
T&D were a direct bolt on for my 360-1s
I know your limited on the O.D of the springs you use and you have to have .100" of valve stem above the retainer or you can have issues.
Re: need help with T&D rockers [Re: 412 SB Duster] #707319
05/25/10 02:42 PM
05/25/10 02:42 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
you tried lash caps?
Re: need help with T&D rockers [Re: mopar dave] #707320
05/25/10 02:49 PM
05/25/10 02:49 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
use a piece of fishing line to check and start grinding on the rockers. no big deal. use the string to test fit. you dont need much.
Re: need help with T&D rockers [Re: rebel] #707321
05/25/10 02:52 PM
05/25/10 02:52 PM
Mt Morris Michigan
Mt Morris Michigan
using a 1.550 spring and .020" stem above the retainer. can lash caps fall off?
Re: need help with T&D rockers [Re: mopar dave] #707322
05/25/10 02:57 PM
05/25/10 02:57 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
i had to grind mine a touch
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: need help with T&D rockers [Re: mopar dave] #707323
05/25/10 03:11 PM
05/25/10 03:11 PM
Renton Washington
Triple Threat Offline
Renton Washington
What ratio rocker?
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: need help with T&D rockers [Re: Triple Threat] #707324
05/25/10 03:32 PM
05/25/10 03:32 PM
Mt Morris Michigan
Mt Morris Michigan
1.6 ratio. what # test line?
Re: need help with T&D rockers [Re: mopar dave] #707325
05/25/10 03:40 PM
05/25/10 03:40 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Grinding is done frequently but I think I'd check with one or more of the builders on here about different retainers that offer greater clearance first. RyanJ has considerable sb experience. Good luck.
Damon
Re: need help with T&D rockers [Re: mopardamo] #707326
05/25/10 04:22 PM
05/25/10 04:22 PM
land of the free
ts racer Offline
ts racer  Offline
land of the free
Can you shim the bottom of the rocker arm stand to raise it up?
Re: need help with T&D rockers [Re: ts racer] #707327
05/25/10 05:18 PM
05/25/10 05:18 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I had a similar issue with my Sharps, and My brodix heads. I had to do 3 things. I bought the tool steel retainers, I used a -.050 lock, and I had to shim up my rocker stands. I had to go .080 shim under the stand, and Ryan at Shady Dell hooked me up on them. I have pretty good clearance now. No issues yet, but its still on the stand.
Waiting for TTI to send me 1 header tube for my headers, ine got a little F'd up somehow.
Kasey
Re: need help with T&D rockers [Re: Moparnut426] #707328
05/25/10 05:27 PM
05/25/10 05:27 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
BB here but I was skeptical about the lash caps.... i like them cause it makes the scrub real good and gave plenty of clearance with the 1.645 spring!
Mopar Performance
Re: need help with T&D rockers [Re: moparniac] #707329
05/25/10 09:40 PM
05/25/10 09:40 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
what is the springs part number? what cam are you using? 2" installed height is great, but if you have room you can get retainers and or locks that will/can help solve some of your headache.
I like these cause it doesnt change valve train geometry. Lash caps might help to but it does and will change rocker arm to valve stem scrub.
Re: need help with T&D rockers [Re: rebel] #707330
05/26/10 02:07 AM
05/26/10 02:07 AM
New York
polyspheric Offline
polyspheric  Offline
New York
I see that no one has read any of the 1,000 comments made on this?
Boffin Emeritus
Re: need help with T&D rockers [Re: polyspheric] #707331
05/26/10 03:19 AM
05/26/10 03:19 AM
Mt Morris Michigan
Mt Morris Michigan
the shafts cannot be shimmed. the cam is a bullet with their springs 268/272@50-.712/.688 and spring #vs8100 with 245 on the seat and 595 open. i could set them up at 1.900, but than my pressures would be way to high. the easiest thing would be to clearance them. how much can be taken off without weakening them? i think .030" would do.
Re: need help with T&D rockers [Re: mopar dave] #707332
05/26/10 03:34 PM
05/26/10 03:34 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Of course, the problem with removing metal here is that you're guessing that the manufacturer left extra un-needed material here.
If he did an excellent job designing it (and there's no metal that isn't structurally required), it's going to break right where you cut it - it's a stress riser, and the lower edge is in tension.
Boffin Emeritus
Re: need help with T&D rockers [Re: polyspheric] #707333
05/26/10 03:56 PM
05/26/10 03:56 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
People will give me greif over this, but here goes. I have had several T&D rockers on the shafts do the same thing, but initially didn't notice until taking them off. They found their own clearence. Some of my buddies gave me crap for not catching it, had theirs clearenced by T&D and broke them eventually at the fulcrum. It's up to you, but if it makes you feel better you can take a little off with a dremel, but only a little. Maybe run it a little find how many and how bad the rub and sand them with a dremel tool sanding drum. Don't take any more off than you have to.
Re: need help with T&D rockers [Re: camastomcat] #707334
05/27/10 03:31 AM
05/27/10 03:31 AM
Mt Morris Michigan
Mt Morris Michigan
been awhile since i'v shopped for rockers for the 360-1 head. anyone know whats available for them now?
Re: need help with T&D rockers [Re: mopar dave] #707335
05/27/10 04:02 AM
05/27/10 04:02 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I had the same problem with the T&D rockers on my big block with 2.00" install height (the stem in not much above the retainer.) I changed the locks and settled for 1.950" install height. When I pull the heads to mill off the rocker stands, I will cut the spring pockets 0.050" deeper.
Re: need help with T&D rockers [Re: 451Mopar] #707336
05/27/10 11:38 AM
05/27/10 11:38 AM
Mt Morris Michigan
Mt Morris Michigan
i did'nt have to remove much metal from the rockers to clear. when T&D made the rockers they put a clearance notch in it to clear the retainer, but left an edge on it. i just removed the edge and scooped it out in the middle. the edge was all that was hitting the retainer. don't know how much i'v weakened them if at all, but will see.
