Residual brake valve
#706670
05/24/10 04:58 PM
05/24/10 04:58 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
I learned something new last week.... a guy at a cruise-in told me the reason I couldn't get the brakes on my 64 Polara to bleed right and firm up was because I didn't have a residule valve in my brake line. I installed disks 4 years ago and have never been able to get the rear brakes to bleed right and you have to pump them to get them firm. I have an adjustable prop valve and I just figured that was the issue. I'd never even HEARD of a residule valve but found them on Jegs site. I assume I'm probably the LAST to know this so could someone please educate my dumba$$!
Jeff Adams
64 426 Polara
Re: Residual brake valve
[Re: Ledman_70]
#706672
05/24/10 05:28 PM
05/24/10 05:28 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Sounds like you have too small of a bore for your master, either that or there is must not enough volume.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Ledman_70]
#706675
05/24/10 06:39 PM
05/24/10 06:39 PM
Ledman_70
Central Ohio
Sorry, I should have been more specific. Drum on rear, 74 Dart disks on front, and I believe, a mid 70's Cordoba dual mc. I would think it would have a big enough bore, but maybe not. The mc is obviously higher than the calipers. Did I miss anything else?
Jeff Adams
64 426 Polara
[Re: Ledman_70]
#706676
05/24/10 06:55 PM
05/24/10 06:55 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
Are the calipers correct.Ive seen them where the bleeder isnt in the up position.Pump the brakes and you have a good pedal till you usr thrm again then pump again.I run 69 C body disc drum master with that setup and my pedal is great.Rocky
Chrysler Firepower
[Re: Ledman_70]
#706677
05/24/10 07:11 PM
05/24/10 07:11 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Residual brake valve may be good for you to have.
Allen
Re: 383man
[Re: 383man]
#706679
05/25/10 08:02 AM
05/25/10 08:02 AM
Ledman_70
Central Ohio
The mc is for a mid 70's Cordoba with disc/drum and the calipers are mounted forward with the bleeders on top. The fronts blled fine, but it seems I'm continually getting a little air from the rear. I'm thinking maybe the mc is leaking air somewhere. I don't see any wet spots anywhere.
Jeff Adams
64 426 Polara
[Re: Ledman_70]
#706680
05/28/10 07:26 PM
05/28/10 07:26 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
if you have drums on the rear with orignal type wheel cly's, then you will need the res valve for the rear, or you can install new wheel cly with the expansion rings.. I had the same problem on my dart, then i added the res-valve to the rear (original m/c had them) when i replaced my wore out m/c with a new one. My old original M/c had the valve built in.
Just behind the brake line ports, its a little rubber plug and spring..
