BE&A makes the headlight bucket assemblies to convert 70 fenders to 71 fenders,or replace rusty buckets in 71 fenders. You will have to drill out the spot welds,remove the 70 light buckets,and weld the new buckets into place. BE&A also makes the dual headlight mounting brackets. Those parts,a 71 headder panel,and a headlight wiring harness from either a 71 Cuda,or a 70/71 Challenger will be needed to power the dual headlamps. Now that these parts are available,the conversion is not that differcult. It will not be an inexpensive swap though.
