Numbers on a 318 block? 71 charger #706121
05/23/10 10:32 PM
05/23/10 10:32 PM
S.E. Conn
Hoof Hearted Offline OP
S.E. Conn
Probably not the original block, but i've managed to clean up and read a portion of numbers stamped on the front drivers side, just under the head but I can only read the last 6 numbers.
Any idea what they stand for?
2005 300C Hemi
2014 Ram ProMaster 2500
I Rekey, Repin old Chrysler locks and cut keys by code
Re: Numbers on a 318 block? 71 charger [Re: Hoof Hearted] #706122
05/23/10 10:39 PM
05/23/10 10:39 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
That would be the serial number of the engine. Info on them at this page http://www.hamtramck-historical.com/1971-TSB-Index.shtml see the first TSB in chapter 25.
To check the VIN, look on the passenger side of the block down low.
