Dash Brake light 79 Cordoba #705910
05/23/10 06:34 PM
05/23/10 06:34 PM
Rockford,IL
71Polara383 Offline OP
Rockford,IL
Hey guys I went out and started the doba today and seen the BRAKE light came on in the dash. What could it be, I haven't touched the Parking brake.
Re: Dash Brake light 79 Cordoba [Re: 71Polara383] #705911
05/23/10 11:06 PM
05/23/10 11:06 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
brake light switch is doing it's job. There is probably a brake fluid pressure difference between the 2 sides of the switch. That would indicate a leak somewhere, but I've also seen low brake fluid level trip the light. Double check the parking brake, make sure you didn't catch the parking brake pedal incidentally when getting in or out of the car.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: Dash Brake light 79 Cordoba [Re: GO_Fish] #705912
05/24/10 02:14 AM
05/24/10 02:14 AM
Rockford,IL
Rockford,IL
Thanks GOfish!
Re: Dash Brake light 79 Cordoba [Re: GO_Fish] #705913
05/24/10 01:07 PM
05/24/10 01:07 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
I second that. I occasionally catch the the E-brake and have to either pull the release and/or pull the release and put my foot behind the pedal
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
