carb heat shields #705710
05/23/10 02:55 PM
05/23/10 02:55 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
anybody here run one? thought about fabricating one out of some scrap aluminum i have, but for $25, maybe just better to buy the holley unit.
the bigger question is do they actually work? i already have a 1" spacer. thought about putting some insulation on the fuel line also.
'71 Satellite Sebring 440
Re: carb heat shields [Re: landon1] #705711
05/23/10 03:04 PM
05/23/10 03:04 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I've never tried one, but I don't think they'd be real helpful. If you do try it, I'd place it below your spacer, against the intake. That would make sure it does not actually pull more engine heat into the carb. Make sure what you get is for a Mopar or else you could have clearance problems with your kickdown linkage (if you are running an automatic).
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: carb heat shields [Re: landon1] #705712
05/23/10 04:41 PM
05/23/10 04:41 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
I have the Holley one on my 72 Challenger I think I got it from Jegs it stopped the fuel from boiling in the carb on hot days.
Re: carb heat shields [Re: landon1] #705713
05/23/10 04:46 PM
05/23/10 04:46 PM
ne
broncobra Offline
broncobra  Offline
ne
The ThermoQuad, with it's phenolic bowl, is suppossed to cool the fuel by 20%. This is from the Build a B/RB engine from Mopar Performance. A lot of people still swear by the TQ.
Re: carb heat shields [Re: Boise Chall] #705714
05/23/10 05:01 PM
05/23/10 05:01 PM
IA
landon1 Offline OP
landon1  Offline OP
IA
any chance of a pic on the other side?
