Re: Drilling Throttle Plates??
[Re: 69Cuda340S]
#70527
06/09/08 11:02 PM
06/09/08 11:02 PM
Posts: 451 So. Cal. For Now But Texas Bou...
69sixpackbee
Have you recurved your distributor since the rebuild?
Negative..same distributor advance. MSD billet with all in by 2500.
Some times you have to drill holes with high duration cams. But before you do try giving it more initial advance and that may allow you to turn down the throttle for proper transfer slot alignment.
I have the same initial...16 BTDC. 20-more in by 2500RPM.
My original as-built, 446 had a CR of 9.8:1 with big valve & massaged "906"'s w/ 1.5:1 roller rockers and the TRW 2266 forgings. What has changed is the higher CR thanx to the TRW 2355's W/ Speed-Pro file fit rings, Cometic .027" thick gaskets and the polished, shaved and port matched Stealth aluminum heads. I stepped up to 1.6 roller rockers which give me a theorhetical lift cam of .543" from my D.C. 509/292 cam. I am also running the same but brand new, Crane anti-pumpup lifters. I guess drilling the blades is no biggie. I will probably start with 3/32" (.093") holes.
[Re: 69sixpackbee]
#70528
06/09/08 11:57 PM
06/09/08 11:57 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
I think 20 or more initial with that 509, will give you better idle My cam specs are similiar to a 509, and I run 24 intial. Drilling the plates isn't a big deal. It's filling them back in that's a pita. I've done it, but why not exhaust other options first.
[Re: HemiStan]
#70530
06/10/08 09:03 AM
06/10/08 09:03 AM
Posts: 1,195 Snowing in the north!
Dart 340
moparts member
moparts member
Have you recurved your distributor since the rebuild? I was about to drill holes in my plates but after getting some advice from a member on here and spending some time with the distributor, it runs like a new car!
Can you expand on this a little more please.
[Re: 68LAR]
#70531
06/10/08 11:11 AM
06/10/08 11:11 AM
69sixpackbee
This is ususally caused by the float level being too high. Try lowering the float just for the heck of it. You will probably have to make some carb adjustments after doing this.
I have the center carb just to the bottom of the sightglass (have clear plugs instead of screws) and the outboards are in the middle. I am running a Holley blue pump regulated to 6PSI as the inline gauge confirms.
Thanx! Bud
[Re: dave571]
#70532
06/10/08 11:18 AM
06/10/08 11:18 AM
69sixpackbee
Dave, I have gone as far as 30BTDC and though it did improve it still "dribbled". I know the "509" is not that radical of a cam. In fact, it has been pretty "street friendly" at least for me. Tall gears and a high stall has also been a contributing factor Otherwise, I cannot see why it should be so bad to dial in the idle. I have read where folks have gotten 11-12" vacuum at idle with this cam but the best I ever got was 7". Anyway, I am going to tinker a bit more and play aroud with some of these great suggestions from you guys. I'll keep you posted. Thanx!!
[Re: 69sixpackbee]
#70533
06/10/08 11:39 AM
06/10/08 11:39 AM
Posts: 12,271 Overpriced Housing Central
RobX4406
Won't matter how far you advance the timing if you have fuel dribbling into the engine. You likely aren't getting the 10+" of vacuum because of the rich condition. Try lowering the float level as suggested to start. You should not have any fuel dribbling from the boosters at idle.
[Re: 69sixpackbee]
#70535
06/10/08 12:05 PM
06/10/08 12:05 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Quote: --------------------------------------------------------------------------------
As I said, this is the usual case. I would still lower the outside carb float levels to the bottom of the site glass hole. The next thing I would do is check the power valve and power valve gasket. Make sure that the gasket is the right one for the valve. Make sure the power valve is the right size. If you have the throttle blades to far open, exposing too much of the transfer slots, this will cause an increase in velocity through the boosters and syphon gas. Having the outside carbs float level higher may be causing an over rich condition making it necessary to open the center carb idle speed screw too far and creating the problem you are experiencing. I'm just thinking of different senerios that can cause what you are seeing. Fuel from the boosters comes from the main jets, or power valve. Both feed based on velocity passing through the boosters. With the throttle blades closed and little or no transfer slots exposed, there should be no gas dripping from the boosters. As you open the throttle blades, velocity increases and the gas should begin to syphon as you transfer to the cruise and power circuits.
Your distributor? Is it a stock unit? Are you running vacuum advance? Do you have it hooked to port or to manifold? If to ported vacuum, then try switching to manifold. This will advance the distributor at an idle and cruise, allowing the idle speed to be slowed down.
