727 Transmission #705125
05/22/10 05:08 PM
05/22/10 05:08 PM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi,
Which aftermarket brand of 727 trans is the one to prefer.
I will probably buy a new 727 to my 65 dodge superstock hemi build. Should I go for coan racing, ATI or.... Suggestions.
I will have manual valve body. Thinking of skip the column shift and install a floor shifter instead. I could the easy use a 66 and later 727.
Cheers!
1964 Dodge 330 Max Wedge clone
1965 Dodge Hemi A990 clone
Re: 727 Transmission [Re: Snoddas] #705126
05/22/10 07:44 PM
05/22/10 07:44 PM
Beaverton, OR, USA
Alikazam Offline
super gas
Alikazam  Offline
super gas
Beaverton, OR, USA
http://www.727specialist.com/
Talked to this guy a couple years ago, seems like a good dude.
Re: 727 Transmission [Re: Snoddas] #705127
05/22/10 07:47 PM
05/22/10 07:47 PM
wisconsin usa
moretork03 Offline
moretork03  Offline
wisconsin usa
i have had good luck with the fairbanks i am running
Re: 727 Transmission [Re: Alikazam] #705128
05/23/10 12:22 AM
05/23/10 12:22 AM
West Coast, Canada
Dakota542 Offline
Dakota542  Offline
West Coast, Canada
Have you considered a A518 tranny, if you drive on the street?
Re: 727 Transmission [Re: Dakota542] #705129
05/23/10 02:58 AM
05/23/10 02:58 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
My first choice would be my cable 727 with the column shift. I have the same trans on the 64 but have some problems with leaking (where the cables attach).
Also I dont know if its a good idea shift a column shifter manual. Easy to shift into the wrong gears maybe.
Probably go with a 66 and later 727 with a vintage touch floor shifter.
Re: 727 Transmission [Re: Snoddas] #705130
05/23/10 08:25 AM
05/23/10 08:25 AM
Sweden
Snoddas Offline OP
Snoddas  Offline OP
Sweden
Hi,
Cheers!
Sorry not coan should be https://www.coperacingtrans.com
