Re: 1970 'Cuda Los Angeles built questions.
[Re: autoxcuda]
#704243
05/23/10 11:04 AM
05/23/10 11:04 AM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
My '70 Cuda has the grey primer..........
Where was your 'Cuda built?
L.A. or Hamtramck?
LA plant/April Build..............
Admiration For Multiple Carburetor Vehicles...
[Re: 6bblgt]
#704244
05/23/10 11:40 AM
05/23/10 11:40 AM
Posts: 1,084 Long Island, NY
70plymA34
Long Island, NY
so all la built cars had black primer on the bottom?? was that the norm for this plant??
ALL is TOO inclusive, data from similar SPD vehicles would be beneficial.
define "black" vs. "dark gray" ??
I think you would need to get responses from similar YEAR & EARLY (August-November) or MID (December-March) or LATE (April-July) production
ahhh, very interesting info. my cuda was an earlier production model (10/69). it seemed to have a dark gray primer not black. however it probably has aged over time. Barry brings up some excellent variables with this process. mine was dealer undercoated.
[Re: Stewpar]
#704245
05/23/10 11:52 AM
05/23/10 11:52 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
L.A. or Hamtramck?
Was it a non undercoating car or an optional undercoating car?
Do you have some pictures of the underside you could share?
[Re: 70plymA34]
#704246
05/23/10 11:56 AM
05/23/10 11:56 AM
Posts: 1,169 Richmond, VA
rayztoy
Richmond, VA
My Car: LA plant, 70 Cuda SPD March 70 Dip- Black, on floorpans only, not on upper part of framerails Primer- very dark grey under body color, on upper part of framerails I guess my car wasn't dipped very deep in the dipping tub.
[Re: rayztoy]
#704247
05/23/10 12:10 PM
05/23/10 12:10 PM
autoxcuda
So Cal
Undercoating car or non-undercoating ??
[Re: rayztoy]
#704249
05/23/10 01:31 PM
05/23/10 01:31 PM
Posts: 3,116 Sacramento,California
JRepucci
BS23H0E, SPD 226 Black dip primer, only under coating is in the rear wheel wells and the driver wheel well around the emergency brake cable and pedal mounting bolts.
[Re: JRepucci]
#704250
05/23/10 01:43 PM
05/23/10 01:43 PM
autoxcuda
So Cal
IIRC, you car is a pretty rust free 100% california car with mint body. Never been restored.
How high does the black dip go on in the rear and front wheel wells?
So that is a non optional undercoating car I assume?
Seems like Hamtramck non undercoating cars got a fan of underoating behind the front wheels to to black out behind the tires. I wonder if the LA cars didn't get the behind the front tire undercoating because it was allready black.
That LA 68 Dart I pictured had no undercoat on the front innder panal area either. Don't know about the pedal bolts or E-brake cable hole.
[Re: JRepucci]
#704254
05/23/10 02:00 PM
05/23/10 02:00 PM
autoxcuda
So Cal
Floor
That's clean
So thats the dark black dip showing through the flaked of pink. Does it seem pretty heavy and tough? More than the grey primer at Hamtramack? Like it's not just primer?
Surprized to see the shifter mechanism and shift linkage boot painted over. Was that factory?
[Re: JRepucci]
#704255
05/23/10 02:02 PM
05/23/10 02:02 PM
autoxcuda
So Cal
Yes, Its an unrestored car. 88k miles. The black out in the front wheel wells is just the black dip. This car would be an excellent example of a LA car to OE restore.
Very true. Perfect car to try to OE Gold with.
Are the underside inspection marks real prevelant and mostly still there?
[Re: autoxcuda]
#704259
05/23/10 02:16 PM
05/23/10 02:16 PM
JRepucci
Floor
That's clean
Thats black body seam sealer!
As for the over spray... I cannot figure it out. It looks as though part of the car was repainted after it had partially assembeled. Some of the body plugs are painted... not over spray but painted pink. The car had peices of its original carpet in it when I got it.
[Re: JRepucci]
#704260
05/23/10 02:17 PM
05/23/10 02:17 PM
autoxcuda
So Cal
Dash and grey? under dash
On the Hamtramck cars I've seen the auto shifter boot/cover and shift mechansism natural color. And those Hamtramck car have spray black out around the corners of the carpet and console opening so as not to show body color thru the carpet edges.
Did the LA cars paint over all that stuff?
