Re: Dumb Wiring Question
[Re: Rustydog]
#703837
05/20/10 11:52 PM
05/20/10 11:52 PM
RapidRobert
Take off the ECU/ballast and their attending wiring/pentastar connector to clean up the eng bay then run switched 12V & start 12V to the dist as required and if it's the type where you run both above circuits together to feed it that'll be one less wire and a even simpler/cleaner setup
[Re: Moe]
#703840
05/21/10 01:24 PM
05/21/10 01:24 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
I do not have a diagram of the RTR FireCore Distributor but this should help you out. Just put all of the wires onto one side of the resistor and wire like below...
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: Moe]
#703843
05/22/10 12:30 PM
05/22/10 12:30 PM
Posts: 7,759 So Cal
HealthServices
So Cal
then find a ground (black wire in the diagram) for the distributer
Allen
[Re: HealthServices]
#703846
05/22/10 01:12 PM
05/22/10 01:12 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I'm not sure if you have a wire from the resistor to the voltage regulator But if you do make sure it is spliced into this as well.
After...
Allen
#703847
05/26/10 10:25 PM
05/26/10 10:25 PM
Posts: 304 Enfield, Ct
Moe
Enfield, Ct
Hi Allen, It appears some of the wiring is not OEM. This is the RUN or "hot" wire off the ballast. Red is ground which I can delete. Also my aftermarket tach is not hooked out to - coil? It works. The purple went to + coil. I bought the car like this. Thanks for helping me out. I got it wired. Gun-Shy about turning the key for fear of frying the whole harness.
[Re: Moe]
#703848
05/27/10 01:59 AM
05/27/10 01:59 AM
Posts: 7,759 So Cal
HealthServices
So Cal
The red wire is grounded and spiced into the purple, Blue/green, cluster? I don't see how it could run if it was grounded.
And this cluster was connected to the other end of the resister right?
The other thing I just thought of if you want the resister to stay there is just to put a jumper wire from one end of the resistor to the other leaving the wires as they are.
I heard of guys gutting the resister on the other side so you cannot see the wire connecting the two.
Allen
#703849
05/27/10 02:02 AM
05/27/10 02:02 AM
Posts: 7,759 So Cal
HealthServices
So Cal
I think on your distributor there is another wire that one goes to your after-market tach.
Allen
