turbo 408 #703796
05/20/10 09:53 PM
05/20/10 09:53 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
hi i have a 408 with scat 4340 crank and rods probe pistons 9.3 comp cnc 245-1 indys, i am a turbo virgin ,but a nos junkie car is a 65 valiant 3550 lbs runs 10.80 asp and 9.9@134 on the gas .what size turbo ,cam etc to run around 850 hp and any other info thanks ian
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: turbo 408 [Re: Ian] #703797
05/20/10 11:01 PM
05/20/10 11:01 PM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
Currently, I am building a 392 with home ported Eddy heads with Inconel exh valves, 76 mm turbo, air to air cooler, FAST injection system. It has custom JE 9.5:1 turbo pistons, H-beam rods, forged crank, main and head studs, M1 intake, Hughes 224 duration hyd roller, 4 bolt splayed mains, partial fill, 727 with 4500 converter, Dana with 3.54 gear and 315/60/15 drag radial.
It will be capable of making 900-950 hp, but of course my block will limit me to about 700-750.
Re: turbo 408 [Re: TheOtherDodge] #703798
05/21/10 12:15 AM
05/21/10 12:15 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks mate it sounds like thats were i would like to be . i am 3/4 fill 2 bolt mains std caps studs top and bottom. what boost levels to make that power and your pie sizes ,what are ya turbo specs .thanks ian
Re: turbo 408 [Re: Ian] #703799
05/21/10 08:29 AM
05/21/10 08:29 AM
Houston, Texas
Houston, Texas
I don't have the specs on the turbo yet...not that far...still in the freshening/building of the motor stage.
Re: turbo 408 [Re: Ian] #703800
05/21/10 08:58 AM
05/21/10 08:58 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
once you boost it you'll never go back to NOS. Boost is full time fun.
Coming soon!!!!
Re: turbo 408 [Re: Mr.Yuck] #703801
05/21/10 12:14 PM
05/21/10 12:14 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
i was thinking the bw s400sx4 part 177287 750-1250 hp rated what do ya think
Re: turbo 408 [Re: Ian] #703802
05/21/10 12:22 PM
05/21/10 12:22 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
76mm with out a doubt Precision Turbo
Re: turbo 408 [Re: joshking440] #703803
05/21/10 12:44 PM
05/21/10 12:44 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
is this to big
# Currently the highest-flowing S400SX unit available, with maximum compressor flow over 120 lb/min. Will service 1200+HP.
# Wheel Dimensions: Compressor: 80.3 mm inducer, 115.8mm exducer, with exclusive Extended Tip Technology. Turbine: 95.5 inducer, 87.9mm exducer. Cast in Inconel 713 for high-temperature operation.
# Housing A/R: Compressor .66, with 5.5" hose-type inlet, and 3.0" hose-type discharge. Turbine: 1.32, with 'divided' volute, featuring 'T6-style' turbine inlet flange (4.438"x2.75"), and quick-release v-band discharge flange. Cast in ductile iron.
Re: turbo 408 [Re: Ian] #703804
05/21/10 03:46 PM
05/21/10 03:46 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
buddy runs a 100mm turbo on a 392 sb mopar. tube chasis Omni/TH3, should run 8's w/ 3.73 gears. Getting his lincense this weekend. So far he has run 137 in the 1/8 and 160 in the 1/4 on a 1000ft pass.
Coming soon!!!!
Re: turbo 408 [Re: Mr.Yuck] #703805
05/21/10 10:11 PM
05/21/10 10:11 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
man thats making good power what are the specs of the engine and turbo
Re: turbo 408 [Re: Ian] #703806
05/22/10 12:16 AM
05/22/10 12:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'll get it for you by Monday. I do know it's a W-something motor. This guy used a cast piston 360 with a 510 cam, 4.10's w/ a pro-charger and went 10's w/ 8-10lbs of bost in a 67 valiant. Drove it to the track.
Re: turbo 408 [Re: Mr.Yuck] #703807
05/22/10 12:21 AM
05/22/10 12:21 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks
Re: turbo 408 [Re: Ian] #703808
05/22/10 08:13 PM
05/22/10 08:13 PM
Grande Prairie, Alberta, Can.
CW25 Offline
CW25  Offline
That S400 80mm will be a good match to the 408. You might want a 1.32 hotside depending on the RPM you plan to turn.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
Re: turbo 408 [Re: Ian] #703809
05/23/10 10:42 AM
05/23/10 10:42 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Ok, here some info on the build. 340 X block stroked to 394. W-5 heads, 98mm Percision turbo,749 roller cam 262 @ .050 116 centerline. 8.5:1 CP heat coated pistons forgot to ask what intake & carb...I think it's a Holley HP series carb. 4000 stall, 3.73 gears. He said make sure you have no overlap in your cam and at least 112 or better on the centerline. He has yet to use the trans brake so his boost comes in late around the 100 foot mark. He is just leaving from an idle and dead stomps it. His 60 foot is about 1.75 (he'll be using the brake next time out and trying to get the boost at launch) Says the car should run low 8's at 170 or so. He's only pushing 12lbs of boost and has no coller. MSD w/ boost delay box. Has his timing locked in full at 35* and drops a degree for every lb of boost. He also said he could have only used a turbo in the 80's and ben fine.
Re: turbo 408 [Re: Mr.Yuck] #703810
05/24/10 10:50 PM
05/24/10 10:50 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
thanks guys we have decided it will be easier with twins around 62 any one recommend some nice priced turbos
Re: turbo 408 [Re: Ian] #703811
05/25/10 09:21 AM
05/25/10 09:21 AM
nc
cold85 Offline
cold85  Offline
nc
What makes twins easier?
Re: turbo 408 [Re: cold85] #703812
05/25/10 10:25 AM
05/25/10 10:25 AM
Summit, NJ
W
whiplash Offline
whiplash  Offline
W
Summit, NJ
See Rodney Dangerfield
"If ones got a problem, I don't have to deal with it...."
  • 67 coronet 4dr, 383/727/GVOD, blown, EFI, daily driver
  • 230/238, 114°LSA cam, 1.6 rollers, 9:1 comp, 8 psi boost
  • NEW BEST ET - 12.40@110mph...
Re: turbo 408 [Re: cold85] #703813
05/25/10 11:51 AM
05/25/10 11:51 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
no xross over pipe and the 65 a body would be cut up a fair bit to fit a big single , that beeing said i have only seen 3 a body v8 turbo pics
Re: turbo 408 [Re: Ian] #703814
05/25/10 11:58 AM
05/25/10 11:58 AM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
my bay
Re: turbo 408 [Re: Ian] #703815
05/25/10 01:38 PM
05/25/10 01:38 PM
Victoria, Australia
Ian Offline OP
Ian  Offline OP
Victoria, Australia
more pics
