70 E body turn signal switch with rimblow wheel #70350
06/09/08 08:43 AM
06/09/08 08:43 AM
Dorchester Ontario Canada
3
383SE Offline OP
383SE  Offline OP
Hi guys,I've got a 70 Challenger with a rimblow wheel.My original turn signal switch crapped out and I replaced it with a Chrysler part.Now my horn doesn't work,the horn wiring on the new switch is different from my original.I think the 1970 switch was a one year only thing.Does anybody repop these or have a Chrysler part number? I've seen some advertised on Ebag but it might be the same one as I've already got,any help would be appreciated
68 Dart GT convert
2013 Ram 4x4
Re: 70 E body turn signal switch with rimblow wheel [Re: 383SE] #70351
06/09/08 09:22 AM
06/09/08 09:22 AM
Edmonton , Alberta , Canada
stwheels Offline
stwheels  Offline
Hi Mike, can you post a picture of the new switch you installed compared to the old one?
Do your turn signals work with the new switch?
The horn wire should provide power to the rim blow switch, did you check to see if there is power going through it?
Thanks, Doug
Doug Lepak
Re: 70 E body turn signal switch with rimblow wheel [Re: stwheels] #70352
06/09/08 09:38 AM
06/09/08 09:38 AM
3
383SE Offline OP
383SE  Offline OP
Hi Doug,thanks you restored my wheel a couple years back and it looks great, and yes the turn signals work as well as the brake lights,the horn worked up until I changed the switch. I'll see if I can post some pics.
68 Dart GT convert
2013 Ram 4x4
Re: 70 E body turn signal switch with rimblow wheel [Re: 383SE] #70353
06/09/08 10:03 AM
06/09/08 10:03 AM
stwheels Offline
stwheels  Offline
Good deal Mike, double check there is power going through the wire also.
Doug Lepak
Re: 70 E body turn signal switch with rimblow wheel [Re: stwheels] #70354
06/09/08 09:59 PM
06/09/08 09:59 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
if u ground the wire the horn will go on...
