73 charger headlights and turn signals problem #703370
05/20/10 01:35 PM
05/20/10 01:35 PM
Riverside R.I. U.S.A.
suit-case Offline OP
I fixed my turn signal switch problem the contacts were to long on the new cam.But I still have the other problem.When I turn on the headlights the front turn signals don't work,the left one is very dim and the left could be also but I can't see it.The rears work fine.Any help would be great.
Re: 73 charger headlights and turn signals problem [Re: suit-case] #703371
05/20/10 01:38 PM
05/20/10 01:38 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It sounds like you have ground issues at the sockets. Now that you fixed the turn signals why not go ahead and delete your post on it.
Re: 73 charger headlights and turn signals problem [Re: stumpy] #703372
05/20/10 01:53 PM
05/20/10 01:53 PM
Thank you I will delete the other post,sory I'm new here
