Need tips on running the 440 cooler. Driving is no problem but in trafic and stuff, it goes up and fast. Rad is stock and seems OK, pump seems OK,
It is a HP 440 and still running 10.25 compression and 906 heads. It has about 10 miles on it now, and all is new stuff. Will retarding it run cooler? HP is not a concern, but I do like to smoke them up a bit. Also when warm it idles fast, around 2000 RPM. Then slowly comes back to 900RPM it is a new Eddey carb 750 electric choke. Same thing about 10 miles on it since motor was rebuilt??
Help
