Re: X-PIPE USERS. Want your reviews or opinions.
[Re: MoparDonny]
#702189
05/19/10 06:07 AM
05/19/10 06:07 AM
Posts: 5,902 Athens, Greece
Pyper70
Athens, Greece
I read in a book somewhere that 3" pipes are typically for 500" engines and above. I have a 505 spare and still plan on running 2 1/2" all the way.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Locomotion]
#702193
05/19/10 01:41 PM
05/19/10 01:41 PM
Posts: 15,491 the boonies
aarcuda
the boonies
i have 3" x pipe pipes from my headers thru a pypes x pipe to aar style spintech mufflers. i just hear exhaust and these dump before the rear tire
It's got a cop motor, a 440 cubic inch plant, it's got cop tires, cop suspensions, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
[Re: aarcuda]
#702195
05/19/10 04:08 PM
05/19/10 04:08 PM
Posts: 2,578 sweden
1Fast340
sweden
yup but i also bet they dont dump under the car?
[Re: aarcuda]
#702196
05/19/10 04:30 PM
05/19/10 04:30 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
Happen to have any video or a sound clip of it ?
I have a pypes X pipe on my Torana and will be using an AAR-T/A style muffler too (No room for exhaust pipes over the diff) and was temped by spintechs too, but think they might be Not a ton of choices in that style of muffler it seems
[Re: MoparDonny]
#702198
05/19/10 06:06 PM
05/19/10 06:06 PM
Posts: 1,142 Tucson, AZ
cruzin
Tucson, AZ
I have a Challenger, 469 ci, 3" inch all the way out the back with a DR.Gas X- pipe and Dynomax Turbo if that matters. No drone. From what others indicate, perhaps it is those mufflers. However, it's hard to tell since no one has the exact same combination/setup as you. Is it possible that your X-pipe is the issue. I'm no exhaust expert but maybe you are experiencing some problem due to the design or lack of due to the X-pipe. Supposedly they are not all created equally One other thought and I'm not trying to be a wise azz, but are those mufflers designed to flow in one direction and are the installed properly? Just a thought...
[Re: cruzin]
#702199
05/19/10 10:25 PM
05/19/10 10:25 PM
Posts: 10,209 Someplace you aren't
SomeCarGuy
THe Dr. Gas X pipe worked great for me a few times.
I currently have an H pipe setup and it has awful drone. There are so many variables in any given car, it is hard to suggest anything.
I want my fair share
[Re: radar]
#702207
05/21/10 12:49 PM
05/21/10 12:49 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
68 Fury, mild 440, Hedman shorty headers, 2 1/2" X-pipe, Thrush 19" turbo mufflers, 2 1/2" TTI tailpipes.
Had this exhaust on the car for a long time and had no objections. I
In trying to reduce some vapor lock issues, I blocked the heat crossover in the intake. Upon driving the car I now had a *terrible* resonance around 2000-ish RPM (just a guess, I have no tach). It happened at 'neighborhood' speeds and made the car so obnoxious it was practically undrivable - it had to be a 10-20 dB resonance.
I re-opened the manifold crossover and the noise was gone again.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
