70 cuda alt wire clamp, pic #701195
05/18/10 08:55 AM
05/18/10 08:55 AM
indiana
mopar mike Offline OP
indiana
i have a 70 cuda, with a hemi. need a pic of the wire clip location on the alt to hold the harness in place. thanks moparts
Re: 70 cuda alt wire clamp, pic [Re: mopar mike] #701196
05/18/10 11:53 PM
05/18/10 11:53 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The engineering drawing I saw didn't show a clip on the Hemi alternator, but I have picture that shows the clip for some of the other engines. If the clip was used on the Hemi, only the single black wire to the Batt post would use it.
Re: 70 cuda alt wire clamp, pic [Re: Snoopy] #701197
05/19/10 12:01 AM
05/19/10 12:01 AM
Snoopy Offline
Snoopy  Offline
70-71 Hemi.
Re: 70 cuda alt wire clamp, pic [Re: Snoopy] #701198
05/19/10 07:14 AM
05/19/10 07:14 AM
indiana
indiana
well i hadn't seen one on anouther one from memory, but jim supplied one when he restored my alt. i guess mine doesn't need one? thanks snoopy
Re: 70 cuda alt wire clamp, pic [Re: mopar mike] #701199
05/19/10 03:49 PM
05/19/10 03:49 PM
Snoopy Offline
Snoopy  Offline
If the black wire is long enough, I would use the clip . Maybe one of the OE judges will check in and clarify it's use if that is important to you?
