Transmission decoding #700228
05/17/10 07:53 AM
05/17/10 07:53 AM
Ontario, Canada
K
krep76 Offline OP
krep76  Offline OP
K
Ontario, Canada
I need a little help figuring out a transmission ID pad. I was expecting to find something that resembled the serial number but instead I found this:
392093L2622 7135
How do I determine if this is the original trans
It is in an early build 69 GTX,
Sequence number B157098
Re: Transmission decoding [Re: krep76] #700229
05/17/10 12:59 PM
05/17/10 12:59 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
you are missing some numbers there , that string is on the pan rail on the drivers side of the trans , it should start with PK , that should be PK289209. The number you are looking for , the VIN , either full or partial , is on a raised pad on the passenger side of the trans on the bellhousing area .
Re: Transmission decoding [Re: krep76] #700230
05/17/10 01:40 PM
05/17/10 01:40 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
check your numbers again
transmission sounds like - PK2892093L
assembly date - 2622 = Tuesday, October 1, 1968
unit number - 7135
The assembly date (if 2622 is correct) appears appropriate for a '69 GTX assembled in St. Louis & "scheduled" for the second week of October '68.
What is VIN# of the GTX? VIN# should be stamped on pad RH side of transmission bellhousing.
What is SPD of GTX?
Re: Transmission decoding [Re: 6bblgt] #700231
05/17/10 02:38 PM
05/17/10 02:38 PM
Ontario, Canada
K
krep76 Offline OP
krep76  Offline OP
K
Ontario, Canada
I was wondering if some of the numbers got cut off. The first number right at the corner looked like a 3 but was right at the edge so and 8 would work as well. I will need to spend some more time on my back to look up the other side of the trans to find the right numbers.
The SPD was Nov. 28, 68 out of Lynch Road
