horsepower torque guess #700021
05/16/10 08:59 PM
05/16/10 08:59 PM
st.cloud fl
d-150 Offline OP
Smarter than a 5th grader?
d-150  Offline OP
st.cloud fl
im building a 440 .60 over 10.5 to 1 compression pistons ,stealth heads ,voodoo 603 cam,holley sd intake,750 eddy carb. what horsepower and torque numbers would this combo make.
Re: horsepower torque guess [Re: d-150] #700022
05/16/10 09:09 PM
05/16/10 09:09 PM
Around 450HP/375-400TQ
383man [Re: ] #700023
05/16/10 10:06 PM
05/16/10 10:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am gonna say closer to 500 hp. My build is close to it as it's a .030 over 440 and I have 906 heads and the MP .557 cam. 10.0 comp using the Holley SD intake with a 750 DP and my hp calculates to right about 500 to push my 3700 lb 63 to 11.49. Ron
Re: horsepower torque guess [Re: ] #700024
05/16/10 10:40 PM
05/16/10 10:40 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Should be just under 500hp. Several dynoed builds have put that same combo right at 500hp or a little over, same combo but with a comp xe275hl cam, which is very similar just 5* @050 more duration with that cam.
