Carb tuning help...have Wideband A/F Ratios
#699774
05/16/10 06:23 PM
05/16/10 06:23 PM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
I broke down and bought an Innovate Motorsports LC-1 wideband kit to help me tune in the Duster. It never really seemed right as it would bog a bit when you opened the throttle and I get terrible gas mileage (if i'm breaking 10, i'd be shocked).
Anyway, I have the wideband connected to the passenger side exhaust pipe right behind the header collector (I have TTI headers now). I've got the gauge mounted on the a-pillar.
The car is running a 360 with magnum heads, summit 218/228 .441/.441 cam, tti headers, 600 holley, and the low compression stock shortblock...hooked to a 4-speed with 3.23's.
We unfortunately run E10 fuel here...so 14.1:1 or so is ideal (14.7:1 on E0-all gasoline)
Anyway, the car behaves as follows:
Tip into the gas, the air fuel ratio leans out to about 16-17:1 for a second or two then settles back into the 13-14:1 range on light accel
at steady state low rpm cruise it sits in the 14-16:1 range, but as soon as the throttle is lifted off it richens to 11.4:1-12.8:1
at idle its between 12.9:1 and 14.4:1 depending on the throttle conditions before idling.
at WOT after a second or two it sits at 12.5:1 which seems pretty much ideal.
This is your standard Holley 600cfm 4-barrel carburetor with electric choke...(80457). I already jetted it up two sizes from 64-66.
I'm mostly trying to help the driveablity of the car. I'm really beginning to wonder if this carburetor is not properly suited for this application. I've thought about changing it...but I'm not sure to what...have been looking at Edelbrock AVS carbs as they seem to be the most fine tuneable aftermarket carb out there due to the step metering rods, air door, etc
Any advice would be appreciated!
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Carb tuning help...have Wideband A/F Ratios
[Re: RobX4406]
#699776
05/16/10 07:40 PM
05/16/10 07:40 PM
Posts: 12,801 Benton, IL.
DaveRS23
Master of nothing...
Benton, IL.
The lean off idle is most likely pump shot or power valve related. Most Holleys that I encounter have a 6.5 power valve. Changing to a 9.5 usually helps more than anything else for me. I get my pvs from AutoZone or O'Reillys because they don't charge shipping.
Master, again and still
[Re: Mattax]
#699778
05/17/10 12:10 AM
05/17/10 12:10 AM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
Good. The attachment worked. I agree the Eddy's are more easily tunable than the 4150/60 series Holleys. No drilling and tapping, blah, blah, blah. But you may be giving up too early. You've probably heard it before, but don't tune to an AFR or Lambda number. Use the data as reference points as you seek most power and economy.
Tune the main jets for max power on the dragstrip (best mph) or a dyno. If you use a dyno, you may have to richen a little on the drag strip. Note the temperature and humidity (and altitude).
Sometime the jets for the best power are also the best (leanest) for highway use. However, you can experiment going leaner if you want to get into resizing the power valve channel restriction.
Accelerator pump shot we've already mentioned in the previous post. Setting the initial throttle position so the transition slot opening below the blade looks like a square (yes you have to remove the carb) helps obtain good control with the idle mix screws. The idle mix screws should be set for best manifold vac when the engine is warm, or about 1/4 turn richer from when its too lean. Idle and transition circuits come into play every time the throttle blade is nearly closed, not just at idle.
> Nearly closed results in the highest vacuum readings for a given rpm. As a result, on the chart of afr for vacuum and rpm, the diagonal represents throttle position. In turn, throttle position mostly determines the circuits doing most of the work. In the example chart posted, the power valve did not get activated. > IMHO the best explanations on how Holley carbs work is in the book by Urich & Fisher and published by HP Books. Good illustrations and some pretty good tuning advice. Even after reading Vizzards 'How to build Horsepower' books, various magazine and web articles, some of which are really sophisticated, I still find the HP book is still a great reference.
[Re: Mattax]
#699779
05/17/10 05:25 PM
05/17/10 05:25 PM
goldduster318
Lake Orion, MI
I can't datalog anything but A/F ratio vs time...as I only have the LC-1...no aux box or anything like that. I have a manual vacuum gauge I plan on hooking up so I can take it for a drive with it installed. Unfortunately, its raining today so that's not happening today.
The car idles with 14 in Hg vacuum at idle in neutral (its 4-speed). the cruise is fairly lean at a low throttle opening but richens when the throttle is closed...acts fairly strangely.
I started reading about it a bit...is there an effect on the mixture depending on the air cleaner I am using? I have the 1972 340 trap door one on the car at the moment.
Not tuning to A/F seems different especially since that is one of the major feedback loops in a fuel injected vehicle...other than throttle position, MAP, and sometimes MAF.
[Re: goldduster318]
#699780
05/17/10 11:40 PM
05/17/10 11:40 PM
Mattax
Phila. Pa.
It sounds like you (or you and your assistant) are doing a pretty good job of correlating throttle and afr even without the additional channels.
H'm. I'd have expected a little bit higher idle vac than that based on the cam description, but its not bad. Might want to check out the Barry Grant website for recommended initial timing for the cam duration and cid of the engine.
With a lumpy cam being rich when most closed and leaning out as the thottle opens is pretty much the way it must be. With a less radical cam, it would not need to be as rich at idle, but otherwise its all the same. In other words, as the throttle opens the AFR is supposed to get leaner until 70 to 80 percent open, then it needs to richen up to handle the load. (Yea. that was news to me when I first read it too). Anyway, your cam didn't sound that radical, so maybe it would be better a little leaner at idle.
It can. Urich & fisher cover that. I wouldn't worry about that too much right now.
Once you know what AFR (lamda) your car performs best at, then you can target that number. Every combination will be a bit different. One car will run quickest at 12.1:1 and another might run quickest at 12.5 - likewise one might be fine at 16:1 for high speed (60 mph+) cruise and another have terrible lean surge at that afr.
Also, while you don't want the AFR to spike lean when you punch it, don't worry about it being a little lean for a second or so as it revs up. This is especially true in first and second gears. It only needs to be enriched when its under full load.
Just to be clear, the chart I posted was only for example of where each of the three circuits dominates. The acclerator pump also shows a little bit as those lean numbers around 8"Hg below 2000 rpm. But it is not an example of good AFRs! You can see that transition (and idle) were plug fouling too rich, and the initial pump shot was insufficient.
In contrast is this attached chart from some testing of my most current configuration. Not perfect, but a big improvement. Close enough that it seems safe to now focus on dyno tuning the main jets. Once they are ballparked, I'll come back to idle and accelerator pump circuits.
[Re: Mattax]
#699781
05/18/10 08:32 AM
05/18/10 08:32 AM
Posts: 5,446 Indiana
YO7_A66
Indiana
""The car idles with 14 in Hg vacuum at idle in neutral (its 4-speed).""
I agree with above post. I would have guessed higher on the idle vacuum, maybe in the 15"-16" range. How much initial timing are you using at what idle rpm?
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: goldduster318]
#699782
05/18/10 12:51 PM
05/18/10 12:51 PM
Posts: 531 Virginia
JimG
Virginia
You've gotten some great info so far. I'd just like to expand on one thing Mattax touched on - the condition where you get rich as the throttle opening is decreased - presumably while decelerating.
Mattax mentioned that you should have no more than .020" or so of transition slot exposed at curb idle. Atached is a photo that illustrates the point. The exposed t-slot should look like a square - no more. Is this something you've checked yet?
During deceleration, the manifold vacuum is much higher than at idle. Any exposed t-slot allows additional fuel to be sucked in through exposed t-slots. Remember to check the secondaries too, as some people crank open the secondaries to get the primary blade/slot relationship right. Exposed t-slot is wasted fuel. If necessary, there are other ways to get bypass air so you can get the blade/slot set correctly.
The easiest way to minimize this problem is to get the idle vacuum as high as possible, or more correctly, to reduce the difference in manifold vacuum between deceleration and idle. Remember, orfices that sized perfectly for 14" hg are too big at 22" hg. The greater the difference between idle and deceleration vacuum, the worse this problem becomes.
This is just for future reference (you've got more basics to cover before you even consider this) but in some cases, it it necessary to install transition slot restrictors to improve on the problem you're describing.
Again, you've gotten nothing but good advice above, IMO. I just wanted to expand on the solution to one of the many challenges you face when you attempt to get your carb calibration right side up.
[Re: JimG]
#699783
05/18/10 06:07 PM
05/18/10 06:07 PM
goldduster318
Lake Orion, MI
I have no doubt that the transfer slots may be exposed more than 0.020"...the car does not seem to idle at a speed that is fast enough for it to stay running when coasting down to a stop light without having that cranked open more than I'd like although I will still have to remove the carb and find out. This is the primaries. The secondary curb stop does not seem to be adjustable on this 2003 vintage 80457 carb (its an 1850 600cfm with electric choke). I'm idling the car at 800-850rpm.
I'm running 14 degrees initial and 35 total for timing on this car. The engine has 8:1 Federal Mougal pistons and magnum heads so the compression ratio is still low...likely 8.4-8.6:1. The car seems to like 16-18 degrees of initial timing, but the denso mini starter has a hard time with a hot restart at these levels.
That being said, I may need to add a fuel pressure regulator. I have a holley fuel pump that is putting out about 7 1/2 psi. I noticed that fuel dribbles out of the boosters when you shut the engine off.
For the most part the car runs really good. I'll have to work on it a bit and get back to you guys. The weather hasn't been cooperating the last few days.
[Re: goldduster318]
#699784
05/18/10 08:33 PM
05/18/10 08:33 PM
YO7_A66
Indiana
"I have a holley fuel pump that is putting out about 7 1/2 psi." Definately add the regulator then see how it reacts to the pressure change.
[Re: Mattax]
#699787
05/19/10 04:32 PM
05/19/10 04:32 PM
goldduster318
Lake Orion, MI
Just took it for a quick in town ride and ran cruise vacuums at a variety of engine speeds. It never went below 13 in Hg on cruise and spent most of its time at at least 17. when backed off the gas its about 25.
Apparently the air cleaner changes things because its idling with 17" hg vacuum with the air cleaner on.
Its very difficult to get down to the power valve opening of 6.5" hg. almost never happens unless you open the throttle a good bit (more than half i'd say). Any standard type acceleration happens in the range above its opening. Going to get a 9.5 PV and probably jet it back to 64 from 66 for the next time out.
I will also order a regulator...sounds like I need one. Will check the transfer slot opening when i am messing with the fuel lines.
[Re: JimG]
#699789
05/19/10 10:43 PM
05/19/10 10:43 PM
Mattax
Phila. Pa.
Jim's right. Maybe I wasn't clear when I posted that little 'recap'. What I meant was that each of the points made were valid, but also that they should be done in sequence. First, the fuel level has to be correct and stable. A regulator will help get you there, as could possibly a different pump. But you have to adjust the fuel level or the results from any other change is questionable at best. If the needle and seat isn't too large, you may be able to get it it pretty good even at 7.5 psi. But yes, a regulator or lower psi pump will insure there is no creep in fuel level. Second, get the idle readjusted. Idle settings effect more than just idle. Third, make sure the acclerator pump is actuating immediately on throttle movement. Then once it is, change pump cam and shooters if needed.
These are the basics that need to be addressed first. The sequence will make more sense once you start reading that book. You can read the first 20 pages or so on-line via google books.
[Re: Mattax]
#699790
05/23/10 07:16 PM
05/23/10 07:16 PM
goldduster318
Lake Orion, MI
Well guys...I did the following:
Pulled off the carb and confirmed the throttle blade position...pretty much a square...no trouble.
I added a regulator and set it for 5.5 psi. The car immediately began to idle cleaner and it no longer drips fuel out of the boosters on shutoff.
I did swap in a 9.5 PV and some #65 jets. Other than a low speed surge on cruise (i richened the idle slightly), the A/F ratios are really good. It even idles at 14:1 now. With the new PV, as soon as I go to take off from a light, i'm in the PV and there isn't any hesitation.
Its close enough that I'll have to look at it in a lot of different scenarios. Its good enough that I should get OK mileage and the driveablity is better.
