489 with sure grib Lubrication question #699178
05/16/10 06:15 AM
05/16/10 06:15 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
What kinda lubrication oil can I use on my AAR rearend 489 with sure grib? Castrol LS 90(GL 5) ?
Lau
Re: 489 with sure grib Lubrication question [Re: AAR70] #699179
05/16/10 08:12 AM
05/16/10 08:12 AM
IN
ahy Offline
ahy  Offline
IN
A good gear oil like you propose with an added limited slip friction modifier. The modifier is needed so the limited slip feature works smoothly.
Your parts store will have the friction modifier in a small bottle or tube to add to the oil.
Re: 489 with sure grib Lubrication question [Re: AAR70] #699180
05/16/10 08:13 AM
05/16/10 08:13 AM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
Lau
I use the Kendall limited slip axle additive concentrate in the 4 OZ bottle.
Re: 489 with sure grip Lubrication question [Re: krw71ragtop] #699181
05/16/10 02:20 PM
05/16/10 02:20 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Cone type sure-grips don't require an additive.
From the 70 FSM:
Blue = Clutch Type Sure-Grip
Yellow = Cone Type Sure-Grip
Re: 489 with sure grip Lubrication question [Re: Snoopy] #699182
05/16/10 02:44 PM
05/16/10 02:44 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Cone sure-grips will chatter if you run standard gear oil without the additive.
I would guess the "special lubricant" sold by Mopar already had friction modifier added.
Re: 489 with sure grip Lubrication question [Re: DoctorDiff] #699183
05/16/10 03:13 PM
05/16/10 03:13 PM
Snoopy Offline
Snoopy  Offline
That may be the case, but it does not use the same lube as a clutch type. Maybe the new additives will work with either sure-grip? I have no personal knowledge.
From Hamtramck Historical
Factory Service Bulletin 69-3-1 Page 5
Re: 489 with sure grip Lubrication question [Re: Snoopy] #699184
05/16/10 03:25 PM
05/16/10 03:25 PM
New Jersey
myrddin Online content
myrddin  Online Content
New Jersey
Both those numbers, 2585318 and 2933565 supercede to 4874468 80/90 gear oil. I would use the additive, can't hurt, or can it ?
Re: 489 with sure grip Lubrication question [Re: myrddin] #699185
05/16/10 04:00 PM
05/16/10 04:00 PM
Snoopy Offline
Snoopy  Offline
From what I have read, the original "Fish" oil additive was too slippery for the cone type. I don't know how the cone-types work with the currently available additives. DoctorDiff seems to think they are not a problem. Maybe he will chime in with his recommendations?
Re: 489 with sure grip Lubrication question [Re: Snoopy] #699186
05/16/10 07:57 PM
05/16/10 07:57 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
I use standard (Ford/Spicer) type friction modifier additive for cone sure-grips and late model Dana 60 power-locks with fiber plates.
I use GM friction modifier additive for 8 3/4" power-locks and early Dana 60 power-locks with steel clutch packs.
Re: 489 with sure grip Lubrication question [Re: DoctorDiff] #699187
05/16/10 08:40 PM
05/16/10 08:40 PM
USA
K
krw71ragtop Offline
krw71ragtop  Offline
K
USA
I found out the hard way by not using the additive in a "cone type" sure grip !
Re: 489 with sure grip Lubrication question [Re: DoctorDiff] #699188
05/17/10 04:04 AM
05/17/10 04:04 AM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Thank you guy´s
Re: 489 with sure grip Lubrication question [Re: krw71ragtop] #699189
05/17/10 01:53 PM
05/17/10 01:53 PM
Denmark, Helsingor
AAR70 Offline OP
AAR70  Offline OP
Denmark, Helsingor
Just curious, what was destroied in the diff after you has used oil without additivs? The sure Grip cones,bearings or pinion?
Re: 489 with sure grip Lubrication question [Re: AAR70] #699190
05/17/10 02:46 PM
05/17/10 02:46 PM
Snoopy Offline
Snoopy  Offline
Re: 489 with sure grip Lubrication question [Re: Snoopy] #699191
05/17/10 02:50 PM
05/17/10 02:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
That info is 40 years old. A lot has changed since then. I rather go by the experiences of people using the stuff today.
Re: 489 with sure grip Lubrication question [Re: stumpy] #699192
05/17/10 03:08 PM
05/17/10 03:08 PM
USA
b54406barrel Offline
USA
I'd have to agree. Even the cone-type didn't use regular gear oil in 1970. I have used just straight gear oil in my 6bbl car for the last 30 years though & it still works great after 100K miles. Since it's a cone rear end & it's lasted this long, I'm sure it's cause I've always babied it!
Re: 489 with sure grip Lubrication question [Re: stumpy] #699193
05/17/10 03:14 PM
05/17/10 03:14 PM
Snoopy Offline
Snoopy  Offline
Stumpy,
Are you saying the FSB's are worthless because they are 40 years old? How old are you?
Re: 489 with sure grip Lubrication question [Re: Snoopy] #699194
05/17/10 05:09 PM
05/17/10 05:09 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
What has my age got to do with it. Lubricants have changed in the last 40 years and that makes old info dated and not necessarily correct now.
Re: 489 with sure grip Lubrication question [Re: stumpy] #699195
05/17/10 10:09 PM
05/17/10 10:09 PM
Snoopy Offline
Snoopy  Offline
Stumpy,
I was just giving you a bad time. I was just pointing out that age has very little to with the worthiness of a man or technical information. Sure the information is dated, but so are the parts and problems that are being discussed.
If you had read the SB you would have seen that it addressed problems that were encounter in the field and some fixes. The second paragraph has a statement that a special additive was not required and when used, only temporarily resolved some of the symptoms. It did not fix the problem.
Re: 489 with sure grip Lubrication question [Re: Snoopy] #699196
05/17/10 11:50 PM
05/17/10 11:50 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That FSB is vague and misleading.
What are "special additives"? STP, PowerPunch, Slick 50, Lucas additive, Marvel mystery oil...?
What is the "recommended lubricant" that can only be used? Sounds like it is NOT standard gear oil.
The following quote is taken directly from Auburn's website under cone type limited slip differential- Installation Manual:
-IMPORTANT LUBRICANT NOTE
The Auburn Gear limited-slip differential design has been extensively tested with high quality non-synthetic 80W90 hypoid oils treated with GM or Ford friction additives (3 oz. of additive will treat 1 quart of oil). To avoid differential clutch chatter (noise) and for optimum
performance, use the oil and additive described above. Use of other additive and oil types may cause differential clutch chatter.**
Ford Part Number: C8A219B546A
GM Part Number: 1052358
**Note the similar terminology about "other additive and oil types" that should not be used.
Re: 489 with sure grip Lubrication question [Re: DoctorDiff] #699197
05/18/10 01:46 AM
05/18/10 01:46 AM
Snoopy Offline
Snoopy  Offline
Maybe this will help clear up the "recommended lubricant".
From the 70 FSM.
