Anyone use the Lokar throttle cable/bracket/kickdown?
#698712
05/15/10 08:05 PM
05/15/10 08:05 PM
Posts: 1,665 Milwaukee, WI
Prince_Valiant
Milwaukee, WI
I am fed up with my current set-up...which appears to be a stock throttle cable, a BME throttle bracket, and an unknown kickdown cable (the linkage wasn't there when I purchased the truck). It's a very convoluted set-up that's difficult to work with.
btw, this is a 79 Lil' red truck.
I've got it now where it works okay...but throttle pressure, feel, smoothness is no where near what I'd expect/desire...plus, it's simply a pain to get the kick-down properly adjusted.
The lockar set up looks pretty clean by comparison...anyone have good/bad luck with em?
tia, chris
Re: Anyone use the Lokar throttle cable/bracket/kickdown?
[Re: Prince_Valiant]
#698713
05/15/10 08:09 PM
05/15/10 08:09 PM
Posts: 4,481 Mesa, AZ
Pat_Whalen
super gas
super gas
Mesa, AZ
If you really want something that is easy to install, appropriate for your engine/transmission, and is super easy to adjust, go with the Bouchillon Performance kit. I got mine today, took an hour to install, and am still in the process of adjusting it, but it's super easy to do.
-Pat
#698714
05/15/10 08:13 PM
05/15/10 08:13 PM
Posts: 87 Bama
BigDawg72
Bama
I am running the Lokar kickdown and a similar (meaning cheap knockoff eBay ) throttle cable on my 72 Challenger. I am using a throttle bracket like this eBy Again I really like the setup. It looks and works great. Sorry, but I don't have any pics.
#698716
05/15/10 08:37 PM
05/15/10 08:37 PM
Posts: 251 Lithonia, Ga
36PLYM
Lithonia, Ga
I have had the Lokar for years, no problems. 318 with 340 intake, 1 inch spacer and Demon carb.
36 Plymouth Coupe 318 w/360 heads 518 trans 8 3/4 rear Ga. Tech BCE'78
[Re: 36PLYM]
#698717
05/15/10 11:05 PM
05/15/10 11:05 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have used the Lokar stuff on a number of cars including Mopars and Fords never had a problem with any of them.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Pat_Whalen]
#698718
05/21/10 03:18 PM
05/21/10 03:18 PM
Posts: 1,819 Middle of A Field
OrangeProwler
Middle of A Field
-Pat
His truck already has the Bouchillon setup. At the time I trusted a shop to do the work on the install for me. Its kind of a pain and sensitive to adjust at first but, I felt I got the shift points right but, he'll want something different. At WOT his truck normally would shift 1 to 2nd at 50 mph and 2nd to 3rd at 70 mph. It does have an agressive shift kit from a previous owner and it will always normally chirp the tires on 1st to 2nd shift.
He talked about smoothness and such to be quite honest that transmission has never been soft on shifts even when I purchased the truck with the with the original setup.
The only thing I never messed with on the transmission was the bands so perhaps the bands may need adjusting. Maybe the line pressure is turned up. Normal shifts for the truck 1st to 2nd 15 to 20 mph and 2nd to 3rd at 30 to 35 mph from what I recall and was the same way with the factory 360 4bbl. It always shifted hard but, I thought it was because it has an agressive shift kit and I got used to it. The transmission mount has been replaced too with a new one.
[Re: Pat_Whalen]
#698721
05/21/10 05:52 PM
05/21/10 05:52 PM
Posts: 1,169 Los Angeles, CA
JF_Moparts
Los Angeles, CA
-Pat
Bouchillon ++
After tearing my hair out trying to get the stock kickdown lever to work right (it's never worked well since I went from my 318 to a 340), I got the Bouchillon. What a difference! A great piece, although a little more expensive. It's worth it though - I think it uses a GM truck cable which you can find at any auto parts store.
[Re: PJM]
#698724
05/22/10 02:59 AM
05/22/10 02:59 AM
Posts: 5,923 Athens, Greece
Pyper70
Athens, Greece
I had installed a Lokar on my SLant 6. The problem is they give you a fiddly piece of sheet metal to act as a mount. I had to custom make my own bracketry and return spring. It wasn't difficult, never had done one before. I had set it up for hard shift points where the slant would rev up and chirp tires going into second.
I wanted to go with an easier setup this time around. I have a Duad Quad setup going on my 440, I bought the Bouchillion kit, complete with the throttle bracket and it all mounts together. its a nice clean setup that makes the engine bay look a little modern, but the average person won't know on mine because the whole setup is covered by a six-pack air-cleaner....
Lokars instructions were pretty vague, again with thin gauge sheet metal brackets. The BPE kit comes with instructions on how to install it with Holleys and Carters.
I'll let you know better when I install it
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
#698725
05/22/10 06:23 AM
05/22/10 06:23 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
Ive never got my Lokar adjusted correctly. Wish I never changed
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
