100mmx5 Neon wheel is close enough to go on the 4"x5 A body hub, but it is not recommended. Lug nuts will not seat properly. Attempt this at your own risk and expect to have a huge repair bill if/when you lose a wheel at speed.
If you just want to move up from the 13" wheels, there's plenty of 14"x4.5" A body wheels around cheap. On my '68 V200, I run steelies, 14"x4.5" front, 14"x5.5" rear. Tires are 185x70 front, 215x70 rear. 5.5" wheels are a bit hard to find and run about $100 a pair, 4.5" should go for $10 a pair.
