2002 Dakota pass side floorboard wet... I'm thinking AC #698282
05/15/10 09:34 AM
05/15/10 09:34 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Soaking wet , was not wet in the winter so I'm ruling out a window leak,third brake light gasket, etc. I know some Dakota's have had an issue with brake lights leaking. I can't find the drain tube to save my last dollar. What am I looking for on the firewall? Any techs heard of this being a problem? Other google findings reveal that the V8 Dakotas have to pull tnhe dash to fix this... yikes.......
Re: 2002 Dakota pass side floorboard wet... I'm thinking AC [Re: da50r] #698283
05/15/10 10:15 AM
05/15/10 10:15 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
If you get under the truck, maybe you can poke around that silver insulation stuff, find the drain and push a wire through it if it's plugged.
Re: 2002 Dakota pass side floorboard wet... I'm thinking AC [Re: buildanother] #698284
05/15/10 10:18 AM
05/15/10 10:18 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
What would plug it up?
Re: 2002 Dakota pass side floorboard wet... I'm thinking AC [Re: da50r] #698285
05/15/10 10:36 AM
05/15/10 10:36 AM
Ohio
Todd Offline
Todd  Offline
Ohio
The A/C drain tubes are hard too see but its there. There where some that had a problem with the water running back along the end of the drain tube and inside on to the floor. Thats if its not plugged tree debri ect. TSB 23-010-04 has you put RTV sealer around the tube body to firewall. This was right from the TSB...........SYMPTOM/CONDITION:
Water may enter the passenger compartment between the HVAC housing and the
bulkhead. A foam seal is used to seal the heater housing to the bulkhead. Condensation
from the A/C evaporator can run along the evaporator drain tube and enter the passenger
compartment if the seal between the HVAC housing and the bulkhead is not sealed
properly. This will result in wet passenger compartment carpet when the air conditioning is
operating.
Re: 2002 Dakota pass side floorboard wet... I'm thinkin [Re: Todd] #698286
05/15/10 11:30 AM
05/15/10 11:30 AM
Middle TN
da50r Offline OP
da50r  Offline OP
Middle TN
Thank You! There is an elbow and a 3" extension that was a TSB for the Minivans, a guy on a Dakota forum put that on there as well as siliconed... thanks a lot.
Update: no ac used in 2 days, condensation on the heater/ac plastic box assembly under the glove box. What's this mean?have not run ac in days!!! It is not anti freeze..
