727 park rod question! #698222
05/15/10 12:38 AM
05/15/10 12:38 AM
Oak Harbor, WA
W
Wicked49670dart Offline OP
W
Oak Harbor, WA
Hey guys finished assembling my 727, everything went great. Did my air checks on the forward and rear clutches and air check front and rear servo's. Checked end play before tear down was .044, now .036. My question is on the park rod. When shift lever is in park and you rotate the output shaft 1/2 the time you have to turn the output shaft a little before park fully engages, is this normal? Can't see fully inside the tail shaft. Once in park it feels solid.
Thanks Matt
70 Dart 3400 496 New Best 6.15@110.37 660ft, 9.76@135 with a 1.34 60ft
Re: 727 park rod question! [Re: Wicked49670dart] #698223
05/15/10 01:16 AM
05/15/10 01:16 AM
Tucson, Arizona
MRMOPAR Offline
MRMOPAR  Offline
Tucson, Arizona
Yes...
68 RR 528" INDY MAXX 07 2500 CTD Southwest International Raceway - IHRA - Tucson, AZ
Re: 727 park rod question! [Re: MRMOPAR] #698224
05/15/10 12:15 PM
05/15/10 12:15 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yup perfectly normal. The parking pawl just needs to engage into the gear teeth in part. Park forces the pawl over on a spring, but until it's seated (With some rotation) it won't be locked.
Perfectly normal...
Re: 727 park rod question! [Re: Wicked49670dart] #698225
05/15/10 05:49 PM
05/15/10 05:49 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A pic of the parts involved.
Re: 727 park rod question! [Re: John_Kunkel] #698226
05/15/10 09:43 PM
05/15/10 09:43 PM
Oak Harbor, WA
W
W
Oak Harbor, WA
Thanks Guys, just double checking. don't want to pull this out again if I don't have too! Thanks Matt
