Re: B-body brake question?
[Re: mc4406]
#697957
05/14/10 07:39 PM
05/14/10 07:39 PM
Posts: 601 Clintwood VA
johnedod
Clintwood VA
I'd check the rubber line going to the tee on the rearend. They can deteriorate from the inside out.
Johnedod 68 Road Runner 71 Road Runner 78 Power Wagon
[Re: mc4406]
#697958
05/14/10 07:39 PM
05/14/10 07:39 PM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
Manual brakes?
How much free play at the pedal?
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
[Re: HealthServices]
#697960
05/14/10 07:41 PM
05/14/10 07:41 PM
Posts: 7,759 So Cal
HealthServices
So Cal
After the brakes lock up remove the bolts that hold the master to the booster or the firewall. Do the brakes release?
Allen
[Re: mc4406]
#697963
05/14/10 07:44 PM
05/14/10 07:44 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I'm suspecting the rod in the master is not fully retracting. This will not allow the fluid to return to the reservior.
Allen
[Re: mc4406]
#697966
05/14/10 07:53 PM
05/14/10 07:53 PM
Posts: 7,759 So Cal
HealthServices
So Cal
If you lossen the fitting at the master for the rear line and the brakes release now, I would suspect it to be a bad master. Of course if the rear brakes are still locked up after doing this, I would suspect it to be something else.
Allen
[Re: mc4406]
#697968
05/14/10 07:59 PM
05/14/10 07:59 PM
Posts: 7,759 So Cal
HealthServices
So Cal
You loosen (removed) the master nuts holding the master to the booster. This should release the interference if there is any.
Allen
#697969
05/14/10 08:05 PM
05/14/10 08:05 PM
Posts: 7,759 So Cal
HealthServices
So Cal
So what happen when you lossen the fitting at the master for the rear brakes? You will have to a least hand thread the nuts so the master won't move when you break the line free.
Allen
[Re: mc4406]
#697971
05/14/10 08:17 PM
05/14/10 08:17 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I have never done it, but I've heard that you can do it.
Allen
