Re: Questions on combo for towing with camper
[Re: MOPAR_AMC_FAN]
#697861
05/14/10 05:09 PM
05/14/10 05:09 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
I would use the Performer intake or a old Holley street dominator intake and the 600 Holley carb.And for a cam...the stock OEM 340 replacement works great in a 318.
[Re: dOc …]
#697863
05/14/10 05:49 PM
05/14/10 05:49 PM
Posts: 992 Simi Valley, CA
MoparJ
Simi Valley, CA
You are going to have RUFF-time towing with a 318 ...uNless you are doing most of the driving and towing on-the-flat.
With a small cam, headers, and a 600 cfm carb, he will be up in the 230-240 horse range and low 310s torque wise. This really isnt that far off of what late 70s 400 numbers. It wont be the most powerful plant up steep hills, but it will tug a trailer. Additionally, it is what he has to work with, so best has to be done to make it a decent tow rig.
Another decent cam would be a Comp XE252, or a small Lunati.
2016 Ram 1500 Crew Cab: 5.7, 65RFE, 4.56 gears with locker, Hemifever tuned, AFE intake, 87mm throttle body, JBA headers, 3" Flowmaster exhaust, split to dual 2.5" exits. 13.57 best ET so far.
Searching for new A or B Body Project!
