Re: Formula for plenum volume alcohol.
[Re: ragingram]
#696276
05/12/10 05:57 PM
05/12/10 05:57 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Not much help but, tunnel ram plenums on race gas fall between the volume of one cylinder to the volume of all 8. I hear bigger plenums will produce higher peak HP on the dyno but, are pigs on the track.......but, then again how much of a pig can 640 inches on methanol really be? ![](/ubbthreads/images/graemlins/biggrin.gif) Here's a ![](/ubbthreads/images/graemlins/bump.gif)
[Re: ragingram]
#696277
05/12/10 06:26 PM
05/12/10 06:26 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I have seen some formulas for doing it BUT it sure wasnt small and it was quite long... I looked at Pipe Max to see what it said... for my engine it shows about 1/5 of the engine volume MIN... doesnt say anything about max or what would be optimum ... sorry I cant help any more ![](/ubbthreads/images/graemlins/wave.gif)
[Re: ragingram]
#696278
05/12/10 07:11 PM
05/12/10 07:11 PM
Posts: 4,213 New York
polyspheric
New York
Back in the day, Bill Jenkins said that plenum volume could be worked out, more or less, on a dyno but not with math since it varies too much with intake CFM, port flow etc. Big carb need less volume etc. Increase the volume in small stages (at the time, by starting with a big plenum and stuffer plates) by removing some stuffers until you just get peak power. Now add stuffers back until the power just begins to fade. Subtract 10%.
Does it have a flat surface you can cut away to form a flange and add a spacer?
Boffin Emeritus
[Re: polyspheric]
#696279
05/12/10 07:34 PM
05/12/10 07:34 PM
MR_P_BODY
I did my BB tunnel ram so I could add different sizes of inverted V plates to change the volume... I started out at a little better than 3/4 of the engine volume with no plates ![](/ubbthreads/images/graemlins/wave.gif)
Post deleted by Defbob
[Re: polyspheric]
#696280
05/12/10 07:48 PM
05/12/10 07:48 PM
[Re: ragingram]
#696282
05/12/10 11:40 PM
05/12/10 11:40 PM
#696283
05/13/10 12:26 AM
05/13/10 12:26 AM
Posts: 78 Canada/USA
ragingram
Canada/USA
mid 600's inch square
wouldn't cubic inches apply here ?
yes you are right. I should read my stuff over more often ![](/ubbthreads/images/graemlins/wink.gif)
[Re: ragingram]
#696284
05/13/10 09:34 AM
05/13/10 09:34 AM
Posts: 2,008 Sweet Home Alabama
MRMOPAR622
Sweet Home Alabama
James Monroe is the man you need to talk to. He told me on my tunnel ram it was more important that the runners be equal than worring about the size. I have the Indy tunnel ram & I had it ported before sending it to Ron's and James said it was fine,but I don't have as many cu. in. as you. But I have learned this,the Mopar engines want more fuel than then chevy engines with equal HP. James is sometimes hard to reach,but Jermey @ Ron's is aso very helpful.
"To Be The Man'You Have Got To Beat The Man"
"T/D and Pro-Bracket Racer"
#696285
05/13/10 01:51 PM
05/13/10 01:51 PM
polyspheric
New York
They used wood blocks, sanded to round the edges and coated with varnish. A V is a convenient shape, but it does change the amount of cross-breathing between banks slightly. You can also hang a V etc. from the top (upside-down) as long as it doesn't mask the entries. If the top is much wider than the entries, add full-length cylinder sliced lengthwise with 1/2 on left and right. They don't have to be solid, or even completely sealed, as long as the joint is pretty small, like 1/8" maximum. Best shape depends on what the interior looks like, a wide flat floor is easy, runners almost intersecting in the middle is bad.
Boffin Emeritus
[Re: MRMOPAR622]
#696286
05/13/10 03:36 PM
05/13/10 03:36 PM
