Questions about relocating the battery.
#696105
05/12/10 02:30 PM
05/12/10 02:30 PM
Posts: 154 Escondido, CA
64physhy
Escondido, CA
I'm relocating my battery to the trunk ('74 Duster)and have a couple questions. 1. Where on the battery box should the vent tube go? High, low, or does it matter? 2. Ground; I know normally, you would ground to the frame, but since it's uni-body, couldn't I just ground it anywhere on the body? I was thinking of grounding it to the vertical support toward the rear where the jack stows. 3. Routing of Positive cable; I'm also going to be mounting a kill switch on the bumper. From there, should I route the cable under the car inside the frame rail, outside the frame rail, or should I route it inside the car and go through the firewall?
Thanks in advance for recommendations, and pics would be greatly appreciated.
Thanks, Dave
Re: Questions about relocating the battery.
[Re: 64physhy]
#696107
05/12/10 06:16 PM
05/12/10 06:16 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
My battery was on a tray--no box. Venting i don't think is a big issue in the trunk. I also had a rear firewall between the seat and rear diagonal supports---i believe that is required for a rear mount battery--or maybe it was for a fuel cell---per NHRA. I don't remember which mod required that to go in but i feel its a good idea anyhow.
As far as running the cable, i ran it through the inside of the car and ran it under the drivers sill plate (be carefull putting the screws back in), but there was a "channel" that had all the wires for the taillights and what not running through it and thats what i ran it through. I feel the less stuff on the outside of the vehicle, the better---except for fuel lines of course. But electrical and brakelines, i put them all in the car.
Grounding, i welded a bolt to the trunk floor so it was like a stud sticking up. for me this worked the best, and you know for sure its always a good contact. I also used it to ground other relays i had in the trunk. But to answer your question, as it is a unibody car, any where on the car is fine. Just make sure the connections are clean of rust and paint.
Outcast Dodge guy.
[Re: Hemiruss]
#696110
05/12/10 09:06 PM
05/12/10 09:06 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
Another option to get around the venting issue is dry cell batteries. They can also be mounted in any postion except upside down.
If you just wire the positive cable through the kill switch. It will not actually kill the engine. The charging system will render it useless.
It's a bit more wiring but a safer and NHRA track legal set up is to run the alternator wire right back to the battery and run a charge wire from the rear switch to feed your fusebox. I also like to use a Ford style solenoid at the rear. This set up leaves the big heavy starter wire dead until cranking.
[Re: Magnum]
#696114
05/12/10 10:56 PM
05/12/10 10:56 PM
Posts: 9,159 Tucson, AZ
Ramrod39
My New Title
My New Title
Tucson, AZ
Are you saying that just running the positive cable through the kill switch is not NHRA legal?
[Re: Magnum]
#696116
05/13/10 10:27 AM
05/13/10 10:27 AM
64physhy
Escondido, CA
The instructions that came with the switch only show the positive lead hooking up to it. Makes sense though that it won't kill the car. So, let me get this straight; run the alternator wire directly to the battery, then from the battery, both the alternator wire and positive cable will go through the switch. Alternator wire goes to the fuse block, and positive cable to the starter. I'm kind of lost on the relay part. The smaller wire to the starter goes through something, not sure if it's a relay or what, but the big one doesn't go through anything. I had another car once that wasn't a Ford and someone put a Ford relay on it, and it never cranked or started right until I took that relay out.
[Re: 64physhy]
#696117
05/13/10 06:49 PM
05/13/10 06:49 PM
Magnum
The only thing I would add to this diagram is a saftey neutral switch wire. With a Ford starter solenoid it will have 2 large and 2 small lugs. To energize the solenoid it needs pos and one lug which will be the small yellow wire from your Dodge starter relay which is hot during cranking. The other lug needs to be grounded. This will come from the transmission saftey neutral switch when in Park or Neutral. Also for a 2 lugs on your Dodge starter will need to be permanently crossed together.
[Re: HealthServices]
#696119
05/14/10 11:26 AM
05/14/10 11:26 AM
64physhy
Escondido, CA
Thanks for the schematics. I just picked up the Ford Solenoid, now I'm going to go out and try to get this all wired up.
Wouldn't it be easier, and work just as well, to run the hot wire from the alternator back to the cut off switch, so that when the switch is turned off, it also cuts off alternator power to the rest of the system? So the wire would go from the alt to the switch, then from the switch to the starter relay. That would eliminate the need for the Ford Solenoid and all the other extra wiring, and kill the car when the switch is shut off, unless I'm missing something here
[Re: 64physhy]
#696120
05/14/10 11:58 AM
05/14/10 11:58 AM
Posts: 7,759 So Cal
HealthServices
Why would you even post that?
So Cal
You mean like this? This is the way I currently have mined wired. I do not like it because of two things.
- 1. One constant switched large hot wire to the front at all times. If this shorts for any reason it can cause a lot of damage.
- 2. One smaller hot wire that is constantly hot even when the switch is off,
Do it once because if you are like me, you may never find the time to change it to the way you would like it later.
Allen
Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first.
Life was a little easier when I was just a wrench.
#696121
05/14/10 12:07 PM
05/14/10 12:07 PM
Posts: 7,759 So Cal
HealthServices
So Cal
It would be a good idea to put a fusable link at the battery. couple more versions here https://board.moparts.org/ubbthreads/show...page=0&vc=1
Allen
#696124
05/14/10 01:07 PM
05/14/10 01:07 PM
64physhy
Escondido, CA
I have an MSD E-curve. The red wire from it goes to the coil, and so does an orange one. The original positive wire also goes to the coil, so on the positive side of the coil, there's the positive and the red wire to the MSD (power). The only other wires to the MSD are a green one (tach) and a black one (ground). So wiring it in any of the ways that the alt power is cut off with the switch should cut off the ignition. Like I said, I really hate wiring.
I currently have the engine out to drop in my stroker after I get it all wired up, so it's important that its right so I'm not cranking forever or have something go wrong during break-in. Which just made me think of another question, I'm running an electric fuel pump, that's also not wired up yet. So one wire to the ignition, and the other to the Cut-off switch so power is cut on it with the switch off? Or would it somehow have to run through the Ford solenoid, too? I hate wiring.
[Re: 64physhy]
#696126
05/14/10 01:51 PM
05/14/10 01:51 PM
Posts: 7,759 So Cal
HealthServices
So Cal
With only a two prong switch and a ford starter solinoid try this...
Oh the green wire is the wire that would normally go to the starter.
Allen
#696128
05/14/10 02:57 PM
05/14/10 02:57 PM
64physhy
Escondido, CA
That one looks easy enough. The alt wire is still always going to be hot though. I guess it's always hot with a stock set-up too, isn't it? Thanks again for your patience and help. Where in So Cal are you? I plan on getting this thing to the Barona track sometime this summer.
[Re: 64physhy]
#696129
05/14/10 03:18 PM
05/14/10 03:18 PM
Posts: 7,759 So Cal
HealthServices
So Cal
I'm in orange county basically N. Tustin, one day I'll swing by Barona just to see what it is like.
Yes the alt will be hot always if routed that way.
Allen
#696131
05/14/10 03:50 PM
05/14/10 03:50 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
With just a two prong switch, you could mount 2 master switches and use a tandem link rod to switch them on and off. This way if you were to use Rob's version of wiring it would look something like this If I understand how Rob was saying it.
Yep that's it.
Allen, you becoming the master of photoshop? Nice work.
[Re: RobX4406]
#696132
05/14/10 03:53 PM
05/14/10 03:53 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Thanks Actually this just using the paint program with Vista! But I am learning more stuff on photoshop, and now learning a little about moving gif. I started with these pictures... https://board.moparts.org/ubbthreads/show...part=1&vc=1
Allen
#696133
05/14/10 09:20 PM
05/14/10 09:20 PM
64physhy
Escondido, CA
Would it make a difference if I routed the power to the Disconnect Switch first, and then go to the Solenoid? In all the examples, it's going to the solenoid first, then to the switch. I'm using a Mac, or I'd draw I diagram on paint, but what I'm thinking is : Battery to disconnect Disconnect to solenoid Solenoid to Starter Starter to hot terminal on Relay Wire from Relay to Solenoid (Green Wire on above diagrams)
Pretty much the same as the examples, except going through switch first, and no running the hot wire for the relay all the way back. Will this do the same thing?
I've got the Alternator to Batt routed, and got a circuit breaker to put in line.
[Re: 64physhy]
#696134
05/14/10 09:27 PM
05/14/10 09:27 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Going to the battery side of the switch then to the solenoid, gives you more potential for voltage loss. Each additional spice and connection to the starter means more voltage loss at the starter.
This is why I put the cable going to the starter first then to the starter relay rather than the other way around. Less potential for voltage loss.
And with this way of thinking you could have one line go directly from the battery to the switch instead of from the battery to the solenoid and then to switch.
But at the same time I do not like a lot of connections at the battery itself, so using the battery side of the ford solenoid as a power take off is good.
Allen
#696135
05/14/10 09:36 PM
05/14/10 09:36 PM
Posts: 7,759 So Cal
HealthServices
So Cal
Boy I'm loss as to which diagram you decided to use. I photochop a dual switch in place of the single I have. This will give you an idea what I mean by using two master disconnects. If you have a high amp alternator and want to disconnect it, this would work rather than using a very expensive high amp 4 prong disconnect.
Allen
#696138
05/14/10 11:07 PM
05/14/10 11:07 PM
Posts: 7,759 So Cal
HealthServices
So Cal
There is no wire from the starter to the mopar relay.
The only heavy wire you need is the one from the ford starter relay to the starter, and the ford starter relay to the battery.
Everything else can be lighter guage.
Allen
#696140
05/14/10 11:10 PM
05/14/10 11:10 PM
64physhy
Escondido, CA
Yeah, it was an idea I was kicking around until I realized that if I did it that way (not the way of the diagram, the way in my head), I would only have power when cranking because of the solenoid.
[Re: 64physhy]
#696141
05/14/10 11:11 PM
05/14/10 11:11 PM
Posts: 7,759 So Cal
HealthServices
So Cal
8 guage from alt to battery is good.
8 would be good from the master switch to the mopar starter relay as well.
14 would work for the starter signal.
Allen
[Re: 64physhy]
#696143
05/14/10 11:15 PM
05/14/10 11:15 PM
Posts: 7,759 So Cal
HealthServices
So Cal
eh, its alright I'm taking care of the little one today and work was slow. Keeps my mind going Make sure you jumper the two posts on the starter. These two if you use a mini starter.
Allen
