Re: Car won't start from the key
[Re: 7DRRunner]
#69575
06/08/08 07:37 AM
06/08/08 07:37 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
KEEP IT SIMPLE Neutral safty switch.
[Re: stumpy]
#69577
06/08/08 12:08 PM
06/08/08 12:08 PM
If it's an auto then it has a nss.
This was the problem with mine.
[Re: orangemonster]
#69583
06/09/08 01:16 AM
06/09/08 01:16 AM
Posts: 8,089 Sorrento, BC, Canada
4speeds4me
IIRC, there's a difference between NSS on 68 and prior autos VS 69 and later. Not sure if this is what is affecting you or not, but it may be. In the early ones there was only one wire to contend with, as the NSS was only that. In 69 the NSS and backup light switch were contained as a unit. The "comb" on the valvebody changed accordingly. Not saying this is your problem, but while we're throwing options out...
2 Demons...no, not my kids!
[Re: orangemonster]
#69585
06/09/08 12:36 PM
06/09/08 12:36 PM
Posts: 32,960 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
The center terminal is the start ground. The two outside terminals are back up lights in and out. Just run a wire from the nss to the ground terminal on the relay.
