some shift kits TF3 to make a manual VB would still have the TPV lever
and it would be tied back with the hillbilly strap
with it hooked to the TPV linkage the light throttle shifts would not be as harsh like a full manual with high line pressure
tieing it back will make it shift a little harder at light throttle
IIRC anyways
deff need to know what you got,your right,it will burn itself up in short order if it needs the TPV hooked up for auto/manual shifts
my CRT full manual VB has a nub and no linkage will fit on it
does it have any auto shift features when in drive?
