Your Thoughts on turboing a 96 Ram #694771
05/11/10 09:03 AM
05/11/10 09:03 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
Truck is bone stock 4X4 with a magnum 360. I have two turbos off an 06 an 07 Cummins. I also have the stock Intercooler. I am not looking to race the truck but it has NO GUTS at all.. I need it to pull my car and open trailer without having to get my foot on the floor to get the job done.
I was just thinking of 6lbs of boost woulld do it good...and only one turbo. I know I ran 35lbs of boost on a stock cummins turbo without blowing hot air on a stock IC so 6lbs should be real easy on one of these turbos.
How big of an injector would I need? I have an adjustable FPR already.. headers ? Where to get them? What about pullomg timing out?
2011 RAM3500
1967 Fastback Barracuda with some go fast goodies.
Re: Your Thoughts on turboing a 96 Ram [Re: Boosted] #694772
05/11/10 02:30 PM
05/11/10 02:30 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Ill be following this man, sounds cool!!! I would give the guys at squires a call, they know how to pull the timing out and what size injectors to run...
Re: Your Thoughts on turboing a 96 Ram [Re: Boosted] #694773
05/11/10 06:49 PM
05/11/10 06:49 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
You better find a way to fuel that thing. I don't think the Magnum computers like boost.
You may want to look into that.
- Stu Harmon
Re: Your Thoughts on turboing a 96 Ram [Re: feets] #694774
05/12/10 08:11 AM
05/12/10 08:11 AM
Houston, Texas
TheOtherDodge Offline
Houston, Texas
No, there is no good way for the PCM. Your next best route, which for small boost, is an FMU setup. I have a complete one for sale if interested. It includes the booster pump, new lines, FMU discs, relay. Everything needed.
Re: Your Thoughts on turboing a 96 Ram [Re: TheOtherDodge] #694775
05/12/10 08:22 AM
05/12/10 08:22 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
I am starting to think it would be better to trade it in on the next CFC sale..
2011 RAM3500
Re: Your Thoughts on turboing a 96 Ram [Re: Boosted] #694776
05/12/10 03:57 PM
05/12/10 03:57 PM
Houston, Texas
Houston, Texas
Injectors: 24 lb FMS
Timing: Use MSD boost retard
Fuel Control: FMU unit
I ran that combination with no problems. Made 280 RWHP on 6 lb of boost.
Re: Your Thoughts on turboing a 96 Ram [Re: Boosted] #694777
05/12/10 11:48 PM
05/12/10 11:48 PM
Pittsburgh,PA
RTSrunner Online content
RTSrunner  Online Content
Pittsburgh,PA
I was wondering how a turbo would work on my 2001 Ram 5.9 Magnum.I will be watching!
RT
Re: Your Thoughts on turboing a 96 Ram [Re: RTSrunner] #694778
05/14/10 08:29 AM
05/14/10 08:29 AM
GA
Boosted Offline OP
Boosted  Offline OP
GA
well I just bnought an 87 IROC to drive so now I can work on the truck...
2011 RAM3500
Re: Your Thoughts on turboing a 96 Ram [Re: Boosted] #694779
05/24/10 02:34 PM
05/24/10 02:34 PM
Tuscaloosa, Alabama
speedfreak440 Offline
Tuscaloosa, Alabama
swap a 12V Cummins in it.... And DONT leave it stock
