can someone read my ring pattern
#693253
05/09/10 03:51 PM
05/09/10 03:51 PM
Posts: 427 Sparks,Nv.
pete
super street
super street
Sparks,Nv.
Re: can someone read my ring pattern
[Re: pete]
#693254
05/09/10 03:55 PM
05/09/10 03:55 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
Is this a used set you are installing in your case, or a new set? What was the backlash? Looks to me like not enough shim... (pinion not back far enough.
[Re: pete]
#693256
05/09/10 04:14 PM
05/09/10 04:14 PM
moper
Columbia, CT
What was the backlash before you started? If you just upgraded the carrier then you don't disturb the pinion... I've nevet had issues doing that. The depth should not have changed. Just get the backlash where it was when you started and you should have been good to go.
[Re: pete]
#693259
05/09/10 05:39 PM
05/09/10 05:39 PM
moper
Columbia, CT
Exactly what did you do? Step by step...
[Re: moper]
#693260
05/09/10 07:43 PM
05/09/10 07:43 PM
pete
super street
super street
Sparks,Nv.
Wish I could tell you but it was about 4yrs ago. Just now starting to drive a lot. But never the less what does the wear pattern say. Pete
[Re: pete]
#693261
05/09/10 08:05 PM
05/09/10 08:05 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
Thats real high. looks to me the pinion needs to be moved closer to the ring gear.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#693262
05/10/10 05:20 PM
05/10/10 05:20 PM
moper
Columbia, CT
Reason I ask is are you confident in the carrier bearings? Hindsight stinks but first thing wrong was you never, ever take it apart without running a patterns and taking measurements for the backlash. You have to know where you're starting from to know how to put it back. For now, with used gears, you may be better off setting up on the coast side and getting the best pattern you can. It takes very little to make gears noisey permanently.
