can someone read my ring pattern #693253
05/09/10 03:51 PM
05/09/10 03:51 PM
Sparks,Nv.
P
pete Offline OP
super street
pete  Offline OP
super street
P
Sparks,Nv.
My rear is howling under accel and at cruise. Starts at about 20-25 mph and continues, but I have not gone over about 40-45. Makes no noise under decel. Thanks Pete
Re: can someone read my ring pattern [Re: pete] #693254
05/09/10 03:55 PM
05/09/10 03:55 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Is this a used set you are installing in your case, or a new set? What was the backlash? Looks to me like not enough shim... (pinion not back far enough.
Re: can someone read my ring pattern [Re: moper] #693255
05/09/10 03:58 PM
05/09/10 03:58 PM
Sparks,Nv.
P
pete Offline OP
super street
pete  Offline OP
super street
P
Sparks,Nv.
Old set new powerloc. That's what I interpret from charts is too shallow of pinion but I'm by far no expert. Pete
Re: can someone read my ring pattern [Re: pete] #693256
05/09/10 04:14 PM
05/09/10 04:14 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
What was the backlash before you started? If you just upgraded the carrier then you don't disturb the pinion... I've nevet had issues doing that. The depth should not have changed. Just get the backlash where it was when you started and you should have been good to go.
Re: can someone read my ring pattern [Re: moper] #693257
05/09/10 04:23 PM
05/09/10 04:23 PM
Sparks,Nv.
P
pete Offline OP
super street
pete  Offline OP
super street
P
Sparks,Nv.
I was positive I had it the same, but I've got noise and fairly loud.
Pete
Re: can someone read my ring pattern [Re: pete] #693258
05/09/10 04:41 PM
05/09/10 04:41 PM
Sparks,Nv.
P
pete Offline OP
super street
pete  Offline OP
super street
P
Sparks,Nv.
Better pic of drive side wear pattern. Pete
Re: can someone read my ring pattern [Re: pete] #693259
05/09/10 05:39 PM
05/09/10 05:39 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Exactly what did you do? Step by step...
Re: can someone read my ring pattern [Re: moper] #693260
05/09/10 07:43 PM
05/09/10 07:43 PM
Sparks,Nv.
P
pete Offline OP
super street
pete  Offline OP
super street
P
Sparks,Nv.
Wish I could tell you but it was about 4yrs ago. Just now starting to drive a lot. But never the less what does the wear pattern say.
Pete
Re: can someone read my ring pattern [Re: pete] #693261
05/09/10 08:05 PM
05/09/10 08:05 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Thats real high. looks to me the pinion needs to be moved closer to the ring gear.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: can someone read my ring pattern [Re: bigtimeauto] #693262
05/10/10 05:20 PM
05/10/10 05:20 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
Reason I ask is are you confident in the carrier bearings? Hindsight stinks but first thing wrong was you never, ever take it apart without running a patterns and taking measurements for the backlash. You have to know where you're starting from to know how to put it back. For now, with used gears, you may be better off setting up on the coast side and getting the best pattern you can. It takes very little to make gears noisey permanently.
