Re: Chassis Dyno Results! [Re: 440Jim] #693207
05/09/10 08:18 PM
05/09/10 08:18 PM
houston texas
gremlinsteve Offline
houston texas
going to be a stout piece...nice numbers
steve
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Chassis Dyno Results! [Re: 440Jim] #693208
05/09/10 08:57 PM
05/09/10 08:57 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
It was Fat as Hell rejetted the carb
I know chassis and engine dyno load etc is different, but that seems odd when the engine dyno showed 14 A/F ratio???
ive also read several post that jetting for max powor on the chassis dyno then having to rejet for best ET at the track!
Mopar Performance
Re: Chassis Dyno Results! [Re: 440Jim] #693209
05/10/10 10:15 PM
05/10/10 10:15 PM
Biloxi, MS.
DusterMel Offline OP
Biloxi, MS.
Not sure why, the Eng was Dynoed in Pa and the chassis dyno was done in south Ms, so possibly the difference in the climate? 18.65 is what the A/F ratio was we got it to 12.69 that's we're it made peak HP.
440 cid sb 75 Duster.
