big block fuel pump push-rod problem #692981
05/09/10 08:33 AM
05/09/10 08:33 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
Wishing to tap into the collective... I have a friend with a '68 Charger R/T. He's been going through push-rods for the fuel pump like no body's business. He replaced the purple-shaft cam he had in it for nearly 15 years. After that, he's gone through two different cams, two different fuel pumps and about 5 different fuel pump push rods. All situations end the same, the push rod is damaged and worn down. When he replaces the push rod, he claims it moves freely in the guide hole. One local suggestion is the oil he's putting in now has no zinc in it. They suggest Royal Purple.
Personally, I've been changing my oil over the years and have never had a push rod problem. There are countless 440 running around and I don't see a rash of fuel pump push rod failures....
Thanks for any insight.
Troy
Troy
Houston Mopar Connection Club
Re: big block fuel pump push-rod problem [Re: hemi68charger] #692982
05/09/10 09:40 AM
05/09/10 09:40 AM
florida
P
PJM Offline
PJM  Offline
P
florida
What brand pushrods is he using? What cam is he running?
Re: big block fuel pump push-rod problem [Re: PJM] #692983
05/09/10 11:21 AM
05/09/10 11:21 AM
get a new confirmed hardened p rod (maybe even a low mile oe one made way back if all else fails). (not sure which new one to recommend) but I have faith in Dave Hughes'stuff if he offers them. there was an comprehensive thread on this awhile back if you can retrieve it. Always want enough zinc but the p rod is the #1 prob. EDIT MP cams have ALOT of quality control probs also (& valves)
Re: big block fuel pump push-rod problem [Re: hemi68charger] #692984
05/09/10 05:48 PM
05/09/10 05:48 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Your friend might try the brass-tipped pushrod from Mancini:
http://chucker54.stores.yahoo.net/fupupubheen.html
There is also one made from solid bronze, can't remember who offers it.
Re: big block fuel pump push-rod problem [Re: John_Kunkel] #692985
05/09/10 06:31 PM
05/09/10 06:31 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I would look for a NOS rod. I have seen them on ebay. I would not buy any low quality replacements.
Re: big block fuel pump push-rod problem [Re: mopars4ever] #692986
05/09/10 07:01 PM
05/09/10 07:01 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I would be wary of any NOS pushrods on ebarf considering it's a currently available part still from Mopar . A few years ago mopar had an issue with the pushrods and a rash of failures , no idea if the sysytem has been purged of these bad rods , I use original rods and never had a problem .
Troy one thing your friend needs to remember is that the metal is not just evaporating into thin air , tell him to check the inside of his oil pump to see where it's been going .
Re: big block fuel pump push-rod problem [Re: JohnRR] #692987
05/09/10 08:02 PM
05/09/10 08:02 PM
Lapeer, MI.
todd440 Offline
todd440  Offline
Lapeer, MI.
The lack of zinc in the oil will do it. I'll have to take a pic of some of the ones I've collected. They are over .250 different in length, worn from lack of zinc.
Re: big block fuel pump push-rod problem [Re: todd440] #692988
05/09/10 10:40 PM
05/09/10 10:40 PM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
In addition to the lack of zinc in new oils, and the quality problems of the Mopar rod, what kind of fuel pump is he running?
The spring pressure may be too high in the pump or may be binding causing too much wear..
My be guess would be the lack of zinc in the oil.
Be sure to run oil with extra wear additives, like Valvoline Racing, or Brad Penn...
The fuel pushrod would be the least of the worries if the oil breaks down and the cam/ lifters start wearing out...
Re: big block fuel pump push-rod problem [Re: sthemi] #692989
05/10/10 04:39 AM
05/10/10 04:39 AM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Re: big block fuel pump push-rod problem [Re: nz383man] #692990
05/10/10 02:20 PM
05/10/10 02:20 PM
Maryland USA
beatgoeson Offline
beatgoeson  Offline
Maryland USA
Find a seasoned fuel pump push rod from back in the days,it should be 3-1/4" long. Tell him to stay away from new Mopar rods. They are scary bad.
Re: big block fuel pump push-rod problem [Re: beatgoeson] #692991
07/07/12 02:50 PM
07/07/12 02:50 PM
New York
Dartautobody Offline
New York
Just fired up a 383 that was built by a local shop. Ran the initial break in, then an additional 1-1 1/2 hours a couple days later for some carb tuning, timing tweaks etc. Then upon taking the car out for a test drive it quit.
After swapping out the fuel pump with no success the pump rod was compared to a "core 383". The failed rod was 5/16"shorter. The"core" rod is running.
So is it really possible to have a fuel rod fail that quick? We have Brad Penn break in oil in the engine. Should I be suspecting internal engine damage? The motor has no other signs of problems , even the valves are quiet.
Re: big block fuel pump push-rod problem [Re: Dartautobody] #692992
07/07/12 03:11 PM
07/07/12 03:11 PM
JohnRR Offline
JohnRR  Offline
you want to look at the lobe on the cam and make sure it is ok. Yes the rod will go that quick , once you loose the hardness it just eats itself up. CHANGE YOUR OIL .....
Re: big block fuel pump push-rod problem [Re: JohnRR] #692993
07/07/12 07:11 PM
07/07/12 07:11 PM
Canton, Ohio
Crazy68Dart Offline
Crazy68Dart  Offline
Canton, Ohio
Talk to Howard at RacePumps. Pretty sure he makes them for BB Mopar. He is a good guy and I would have no concerns over quality coming from him.
383, Hemi 4-Speed, AlterKtion, D60
